Phono harmonics - diyAudio
Old 6th March 2004, 02:25 PM   #1
scott wurcer's Avatar
Default Phono harmonics
I still have a complete set of the old RCA STR series of test records. In setting up my preamp I noticed that, as one might think, for lateral information (L+R) the peaks are more accurately tracked than the valleys. This sets up a particular phase relationship for the (even order at least) distortion components from channel to channel. I was wondering if this contributes to the 'LP' sound (i.e. this would be true for just about anyone). Even the best cartridges that I have owned have way more distortion than almost any preamp that I have measured, hence my experiments with open loop preamps.
Old 8th March 2004, 10:09 AM   #2
Werner is offline Werner  Europe
A bit of topic, but since you mentioned open-loop phono preamps, here's a frontend concept of one of mine, the particular values originating from my 21V PSU and the stash of 100nF Siemens MKV caps I have.
My other phono project is, incidentally, around an AD797 in inverted mode, with a, let's see, AD711 in the servo ;-)
Cancelling Harmonics dsavitsk Tubes / Valves 20 10th July 2007 02:11 PM
odd harmonics? Pbassred Solid State 11 5th April 2007 01:17 PM
Speaker's harmonics - against what? anli Multi-Way 2 21st September 2006 07:58 PM
Power amp harmonics ? dakotadave Tubes / Valves 21 15th May 2006 04:39 AM
Artificial Harmonics guitargully Instruments and Amps 1 15th April 2004 07:53 AM
Copyright 1999-2017 diyAudio
