breuer dynamics - diyAudio
Old 4th March 2004, 05:32 PM   #1
pamaz is offline pamaz  Italy
Default breuer dynamics
Is anybody familiar with Breuer Dynamics arm.
I own one , that's sitting on an Oracle delphy MK1 and it's a wonderful piece of mechanic.
In recent times i saw on an hifi review a really similar one ( not to say that to me it's exactly the same!) but was branded BRINKMANN, priced around 4200 in Italy!
In any case i would like to rewire it , and therefore i would like to understand if there are tips and tricks to observe for, while i'm going to dismount it.
Thanks and bye
Paolo
Old 4th March 2004, 08:27 PM   #2
ingvar ahlberg's Avatar
Hi Paolo
Dont rewire the Breuer if wires are not broken, they are alright as is. This arm is a mechanical masterpiece but rather fragile.
The Oracle is a perfect environment for the Breuer, one little tweak is usefull for use with lower compliance mcs (the Breuer was designed for high compliance cartridges): add an extra weight/distance plate, brass is good, of 4-6 grammes between cartridge and shell. Otherwise just be a proud owner
Ingvar
Old 5th March 2004, 08:18 AM   #3
Ciao Ingvar.
Thanks for the suggestion. It's better to keep it like this.
i was wondering to make this rewiring because I was not aware of the quality of the wire itself. And this could be the opportunity to give to the whole arm a checK/cleaning.
Due to some budget problems ( a baby is come!!! and he costs a lot!!!) by now I'm using it with a DL103 ( as you say hi compliance) and with a big surprise I'm not suffering at all with such a low budget cartridge.
I've not a single reason to multiply by 10 or 15 the cost of the cartridge because it's not worth. It's been a discovery to find such a nice match between Oracle Breuer and Denon.
In any case if you have some more infos on this arm, i will appreciate very much to have them.
Thanks and bye.
Paolo
Old 5th March 2004, 08:23 AM   #4
Ciao Paolo
The Denon is a fantastic cartridge, You would only feel fooled if You changed to some expensive exotica, try the extra weigth and see! Somewhere ive got the old Absolute sound review of the Breuer hailing it as the "best arm ever made" ill try to find it and scan if You would like to have a copy
Ingvar
Old 5th March 2004, 09:52 AM   #5
If you can scan that stuff it would be great!
Are you using dl103 too?
If yes, with which interface ?(active stepup, transformer etc..)
In any case thanks a lot for the advice.
Ciao
Paolo
Old 5th March 2004, 10:51 AM   #6
Yes i do use the DL 103 and an Ortofon SPU and a Grado signature. The Denon i use in a Stax 12" arm together with the Hiraga design step-up amp. A 20 kg beast with lead acid
batteries and 2x470 000 uF Capacitors.
Ciao
Ingvar
Old 6th March 2004, 12:40 AM   #7
Buon giorno Paolo
I found a coupple of extra weights, like those i recomended, in my workshop. If You want to try send adress and ill put one in a letter.
Ingvar
Old 6th March 2004, 12:51 AM   #8
Ciao Paolo
Its me again, forgot to say congratulations to the son!!!
About the cost regarding children, dont worry, my son was 18 this January and cost is still rising, but ill be damned if i could find something more satisfying to spend on.
Ingvar
Old 6th March 2004, 10:53 AM   #9
Default bad perspective!!!
I forgot the PS....
thanks a lot Ingvar.
So you are saying that it will be more and more difficult!!!! ( not with the turntable for sure)
In any case Thanks also for the weight, but i think I have something similar in graphite ( made by Art) that an Hifi magazine was giving away at the subscribers.
Therefore give me a few days and I'll come back to you with the impressions on this trick that you're suggesting me.
Ciao and have a nice weekend.
Paolo
PS babies are the best thing that could happen to a man.
Old 13th March 2004, 08:52 PM   #10
icefox is offline icefox  Hong Kong
ingvar,
Sorry to jam in, I am also a owner of the Breuer arm, Type 7.
I am very interested to your tweak about putting weight in the headshell. It sounds like very intelligent design.
May I also have one to try?
I will send my address to you in a PM.
ESL Dynamics, Microdynamics,Macrodynamics michaelpage26 Planars & Exotics 25 14th June 2011 08:31 PM
Dynamics in Loudspeakers gedlee Multi-Way 181 8th October 2007 09:31 AM
My Audio Dynamics/ADC amp needs help! saabracer23 Solid State 5 7th March 2007 06:24 AM
Hammer Dynamics gchrist Multi-Way 7 6th March 2006 04:48 PM
Sony SACD dynamics PH104 Digital Source 0 4th January 2003 01:38 AM
Copyright 1999-2017 diyAudio
