Change my Turntable Stylus and Cartridges
Old 28th February 2004, 04:34 PM   #1
roy1xord is offline roy1xord  Spain
Default Change my Turntable Stylus and Cartridges
Hello
I want to change my old Turntable Stylus and Cartridges. I have a Technics DIRECT DRIVE AUTOMATIC SL-D32; but I donīt know if I can to buy any Stylus and Cartridges, because I lost the manual of this Turntable.
Can I help me, please?
Which are the best Stylus and Cartridges for this Technics Turntable, please?
Thnak you very much!!!!!!!!!!!
Old 28th February 2004, 06:51 PM   #2
R.I.P.
I can't find any reference to your turntable.
And I don't know what cartridges are available in Spain
or their relative cost.
Prices of brands vary quite a lot due to the importer.
I'd generically recommend an Audio Technica AT95E for the
standard typical Japanese S-shaped arm, the cartridge
usually costs barely more than the stylus alone.
(Only applicable to Europe cartridge model I believe)
Ģ16 (16GBP) in the UK.
sreten.
Old 28th February 2004, 08:02 PM   #3
Default mistake
I have a mistake.
My turntable is: technics "DIRECT DRIVE AUTOMATIC" SL-D3
Its stylus is Technics 2700.
Old 29th February 2004, 06:48 AM   #4
wrenchone is offline wrenchone  United States
wrenchone's Avatar
If the turntable uses a p-mount cartridge (I have a Technics SL-DL1 that uses p-mount), then it should be easy to change to another cartridge. My TT came with a Technics cartridge. I got tired of the sound of my system and was thinking of spending a lot of money for new speakers. I instead dumped the Technics cartridge and replaced it with a bottom-of the-line Grado. This changed my system sound enourmously for the better, and I forgot about buying new speakers.
Old 29th February 2004, 10:35 AM   #5
Thnaks for your reply.
I donīt know if itīs P-mount, because I loose the manual.
But I found out a web where are the Features, I donīt understand it, but Could you help me,please?
Itīs:
http://www.ultraelectronicactive.com...rdPlayers.html
Thanks again
roy1xord
Old 29th February 2004, 12:27 PM   #6
R.I.P.
A Grado is an excellent budget choice in the States,
but not so much in Europe due to pricing differences.
In Europe an AT95E is nearly a third of the price of a Grado
Black. I believe its the other way round in the States !
sreten.
Old 29th February 2004, 12:33 PM   #7
R.I.P.
http://www.musonic.co.uk/stylitechnics.htm
has the technics stylus for Ģ28, I'd say a AT95E is far better.
sreten.
Old 29th February 2004, 12:45 PM   #8
R.I.P.
http://www.mantra-audio.co.uk/mantraonline.htm
Prices for the AT95E are very good compared to elsewhere,
(Ģ16 vs. Ģ28.50) the cartridge is only Ģ1 more than the stylus.
sreten.
Old 29th February 2004, 01:32 PM   #9
R.I.P.
Itīs:
Thanks again
roy1xord
What don't you understand ?
The arm does not take P-mounts, standard 1/2" mounting.
Also note if you change the cartridge you need to know how
to align it correctly in the headshell - a web search will help
with this if you want to achieve accurate two point alignment.
sreten.
Old 29th February 2004, 04:28 PM   #10
wrenchone's Avatar
Pmount or standard screw mount, I would get a Grado if you can afford one. Grado uses a moving iron technology that allows the cartridge to have significantly less inductance (~10X less) than a standard moving magnet cartridge. Termination resistance and capacitance is much less critical, and you have fewer problems with electrical resonance of the cartrige inductance with stray (or terminating) capacitance. I have personally found Audio Technicas to be hissy and spitty, and wouldn't use anything these days except for a Grado or a high output moving coil cartridge. In the end though, you use what you can find and afford - it's just my 2 cents worth...
Change my Turntable Stylus and CartridgesHide this!Advertise here!
replacement cartridge and/or stylus for Pioneer PL-200 turntable kimberfonic Analogue Source 1 17th November 2007 01:48 AM
CD cartridges woodturner-fran Digital Source 3 21st June 2007 08:51 PM
Nagaoka used cartridges Panicos K Analogue Source 1 15th October 2006 12:40 PM
Old cartridges Zero One Analogue Source 1 25th July 2006 12:22 PM
Denon Turntable - Stylus question. deanw711 Analogue Source 2 22nd May 2006 05:46 PM
Copyright ©1999-2017 diyAudio
