| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello,
I bought a Nagaoka roller 152 to clean my records collection, but now itīs dirty. So I would like to know if it can to be clean whit water. or How ca I clen it, please? THANK YOU VERY MUCH!!! roy1xord
#2 |
Hi again,
a roller only removes surface dust, it can't clean the grooves. If you use a carbon fibre brush everytime before playing a record it should be all you need. (I clean both sides of the record and my rubber mat with the brush when I only play one side of the record. I have no problems at all with dust build up on records.) sreten.
#3 |
I ever clean my LPs with TRITON x-114, alcohol, and water.
When it is dirty I use the roller and it look clean, but when I see it on the light it have marks of this roller, and the dust which is between the furrows does not leave. So I use a pure bristles brush which donīt clean again, so..... Iīll buy a carbon brush and Iīll try it one more time. Do you use any liquid to clean whith your carbon brush? Because I only know "the triton x-114" formula. Do you know any one which musnīt to clean with water after to use it, please? Thanks again Roy1xord |
#4 |
I've no recent experience of cleaning bad records, e.g. bought
second-hand from a shop, I used to use some stuff you applied and then peeled off. Or dealing with mouldy records - but you can find info on the web. To maintain my records I don't use any liquid at all, only the carbon fibre brush, which does get most of the dust out of a groove - your stylus will clean out the rest (or impact it into the groove wall - why its important to use the CF brush every single time before being played). The only other thing I use occasionally is a stylus brush, I don't seem to have any problems with deposit build up on my stylus. (Extended line contact tracking at 2g) sreten.
#5 |
The Nagaoka record cleaner is actually a pretty effective cleaner. It is soft enough to get down into the grooves, and unlike the record brushes touted above, it actually removes dust etc. rather than simply lining it up. And it does it without applying a liquid, which, if it is not completely removed eventually builds up with dust and so on and comes up on your stylus as crud. There is no perfect record cleaner that I have come across.
The answer to your actual question is 'yes'. You clean the roller under water. You can use a little soap -- in fact it will help make sure you don't accumulate oils on the roller, but make very sure you rinse thoroughly. The thing you need to be careful about is actually the rolling. On a couple of occaisions when I wasn't paying attention, I didn't keep the roller flat, and the sides of the handle scraped the record -- no actual damage, but worrisome enough that I stopped using it. By the way -- probably not a good idea to clean records on the platter since you have to push down pretty firmly, and that might not be a good thing for the bearing. |
#6 | ||
I don't have one so I couldn't definetely say. Pressing a flat section into the bottom of \/\/\/\/\/\/\/\/ would need a very elastic surface. And a fair bit of pressure I'd assume ? Roy1xord said it left dust in the grooves you could see, (presumably the bottom) is he not pressing hard enough ? Quote:
the other hand easily get right down into the bottom of the groove and its not difficult to remove nearly all the dust. CF bushes major adavantage is that they pick up and move the extremely small particles of dust. Larger particles are pushed out of the way by the stylus, its the small particles that can be permanently impacted into the groove. I can't see why anyone would disagree with that you should use a carbon fibre brush everytime before you play a record, no matter how dust free it appears to be. sreten.My other cleaner is a Ronco Vac-O-Rec ! for the really dusty. |
#7 |
Ok, thanks.
But Which is the best DECCA carbon fiber or Hunt EDA Mark 6 Carbon Fiber . I saw this last have 2 lengths of bristles with a piece of velvet in between , and look more effective that DECCA.
#8 |
The only bit you need is the carbon fibre bit, the Hunt is a pain
to use (as are all the carbon fibre brushes with "velvet" pads) and the Decca tends to fall apart. something like this is perfect and not expensive : (you swivel the brush to wipe off the dust on the raised section) They are easy to use on a running record without stretching the belt (unlike the pad types), just hold it tangentially, the right pressure is obvious, (you can feel the friction of the fibres pushing into the grooves), then slide off with a slight sweep as you go. http://www.amazon.co.uk/exec/obidos/...283078-0073464 sreten.
#9 |
It is obvious that a cleaner that only cleans the top of the record is of limited use, since it is the grooves where the action is. But having used the Nagaoka for about a year, I can say that it does a pretty good job -- and yes it is very soft, almost viscous -- and I think it actually goes down into the grooves.
I am not eager to make this into a bone of contention, but its odd to me how certain everyone is that this piece of equipment (that they have no experience of) doesn't work. The poor guy simply asked if it could be washed -- which it needs to be since it really does pick up a lot of stuff from the record. Back when I was using one, my records were bought new and so I didn't have to worry about ground in crud at the bottom of the grooves, and so the Nagaoka worked well (and I am not the only one to think so -- it got good reviews). Whether its up to cleaning used records I do not know. I would think that nothing short of a full blown record cleaner is going to be really effective. And what happens to that line of dust that you sweep off the record with the carbon fiber brush -- doesn't half of it simply get redeposited in the grooves as you swivel sideways and off? |
#10 | |||
If you read the whole thread : Quote:
Regarding a CF brush, all I can say is get one, they are very cheap. They are also easy to use every time you play a record and they work. IMO anyone who thinks a CF brush is not needed is misguided. And anyone who starts using a carbon fibre brush never stops. Quote:
![]() But you soon get the hang of it, but given you can remove 90% of the dust on a record which appears to be perfectly clean, completely down to the bottom of the groove, tell me what else can do this simply and that you'd be prepared to do before every side of a record you played ? sreten.
| Nagaoka MP-50 pickup | plysch | Analogue Source | 43 | 10th June 2011 08:41 PM |
| Nagaoka SW-1 | cervelorider | Subwoofers | 4 | 26th August 2008 01:04 PM |
| Nagaoka used cartridges | Panicos K | Analogue Source | 1 | 15th October 2006 11:40 AM |
| Fostex 206 ES-R (Nagaoka) box | Frank McCrea | Full Range | 15 | 8th September 2006 08:49 PM |
| my new nagaoka swans | lecky | Full Range | 18 | 9th May 2006 03:57 PM |
