Attenuators after a phono pre amp? - diyAudio
Old 24th April 2016, 05:23 PM   #1
JoeDJ is offline JoeDJ  United States
JoeDJ's Avatar
Default Attenuators after a phono pre amp?
Are there any issues involved in putting (quality) attenuators in the line out of a phono pre amp ?
I ask this because my phono pre amp output has a bit too high of an output level .
I have also read conflicting opinions about if it will effect high frequencies.
I tend to believe it does not as it is no different than an amp's gain control .
Old 24th April 2016, 05:57 PM   #2
JonSnell Electronic's Avatar
A pair of resistors forming a ladder is all you need. Say 10k and 10k to ground, that will give you a 3dB loss, halving the signal and halving any noise.
No frequency degrading will happen.
Support for Fender, Marshall and all Valve Equipment including Quad and Leak. www.jonsnell.co.uk
Old 24th April 2016, 06:02 PM   #3
Mooly's Avatar
Jons suggestion is very workable in the real world.
If you have a circuit for the preamp then we might be able to suggest a simple component change to lower the gain of the amp. Doing that would preserve the (presumably) low output impedance of the unit.
Installing and using LTspice IV. From beginner to advanced.
Old 24th April 2016, 07:13 PM   #4
JoeDJ's Avatar
Are not all inline (RCA) attenuators just resistors? .
I prefer not modify any components if a simple inline attenuator will do.
Old 24th April 2016, 07:18 PM   #5
diyAudio Member RIP
Hi, to be specific that will give you - 6dB, rgds, sreten.
Old 24th April 2016, 07:20 PM   #6
Mooly's Avatar
Yes, but they are a network of two resistors configured as a divider and not just a single resistor in series.
Old 24th April 2016, 07:22 PM   #7
Two resistors of same size will do 6dB, not 3 (half the output).
Degradation of the highest frequencies may happen if the load
capacitance is high at the output.
Yes,an "inline attenuator" will do, better connect this at the line input.
Old 24th April 2016, 09:49 PM   #8
GDO is offline GDO
GDO's Avatar
Don't understand the bit too high outputlevel issue...
What do you need attenuate for?
“If you aren't rich you should always look useful.” L.F. Celine
https://www.youtube.com/watch?v=NY5Xtc6YuCg
Old 25th April 2016, 12:29 AM   #9
JoeDJ's Avatar
what do you not understand about that?
Actually, it not "too high" .
It's just that what I got it input into would be a bit happier with a slightly lower input.
Old 25th April 2016, 01:56 AM   #10
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yes - you don't want to raise the output impedance too high or you'll create HF roll-off in conjunction with the cable capacitance as well as increase your noise susceptibility. You don't want to go too low or dynamics of the source will start to suffer.
Better to use a step down transformer.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Will phono pre > passive pre > amp work well enough? soldersmoker Analog Line Level 12 3rd September 2013 07:15 PM
Phono Pre Amp cberman Analogue Source 2 11th October 2012 04:04 PM
Phono pre-amp, TT PSU, mic pre-amp build log ptheskil Analogue Source 0 7th May 2012 03:55 PM
How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input jmartinbaugh Analogue Source 3 25th April 2011 02:24 PM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 10:09 PM
Copyright ©1999-2017 diyAudio
