Old 22nd February 2004, 08:19 PM   #1
Send a message via AIM to megatron
Default technics 1200 pitch correction
hi
i have 2 technics sl-1200 mk2 turntables
heres the problem:
when i put 2 records that are identical on and play them at the same pitch on the turntable one plays a bit faster than the other
how do i fix this?
Old 22nd February 2004, 08:46 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi megatron and welcome.
Excerpt from the Service Manual:
“When the pitch control knob is located at the center of the
position after turning on the power, the green LED indicator
is lit showing the operation condition for the predetermined
speed (either 33-1/3 or 45rpm). The pitch control is variable
in a range of about 8%.
Adjustment should be done on the basis of indicator scale.
Figures on the indicator show approximate percentages for
variable pitch control.
When the strobe dots in 4 stages marked at the peripheral
edge of the turntable appear to be stationary, variation of
individual pitches is shown.
The strobe illumination of this unit employs a
strobe-illuminator LED synchronized with the precise quartz
frequency.
For fine adjustment of the turntable speed, be sure to
effect the adjustment according to the LED illumination.
The LED illumination is not synchronized with fluorescent
lamps.”
In other words:
Remove the platter, remove the plastic cover underneath the platter and turn VR301 (only a tiny bit) which is the +/-0% adjustment of the pitch control. Mark it carefully before turning.
After every small change you’ll have to test till your satisfied with the result.
/Hugo
Old 22nd February 2004, 09:11 PM   #3
ok so.. in order for the pitch to be perfect i have to make sure the dots line up and are stationary?
Old 23rd February 2004, 01:56 AM   #4
nevermind i figured it out and fixed the problem
thanks alot!!
Old 23rd February 2004, 08:11 AM   #5
Netlist's Avatar
Yes. The above description assumed you had no frequentie counter.
In case you have, things become a lot easier.
With your platter and the underlying cover removed and your pitch slider in the middle position (green LED on) connect the counter between TP27 and TP26 (ground). Now calibrate VR301 for 262.08Khz, +/-0.05Khz. This is your +/-0% pitch adjust.
/Hugo
Problem in pitch TECHNICS SL 1210 Willian Pires Analogue Source 4 7th February 2008 04:51 PM
Technics 1210MK3 Pitch Problem JenkoDJ Analogue Source 4 8th October 2007 12:08 PM
tech 1200 pitch warble mixhard Analogue Source 2 10th April 2006 12:38 PM
Technics 1200 MkII Pitch Problem silicuda Analogue Source 6 12th February 2004 10:34 PM
Technics SL-1200 Mk2 pitch control Clark2000 Analogue Source 18 13th August 2003 07:00 PM
Page generated in 0.08942 seconds (72.22% PHP - 27.78% MySQL) with 11 queries
