AES3 / AES42 Microphone System, CNC case - diyAudio
Old 19th February 2016, 03:16 AM   #1
aShure is offline aShure  United States
Smile AES3 / AES42 Microphone System, CNC case
Hey there!
I sketched this concept for a digital AES42 mic. It's quite small to be portable, getting pretty tight on the PCB. I try to construct everything to be CNC milled or turned.
Not yet set on the capsule, I sketched some ideas for large diaphragm capsules. Here's one with four rectangular membranes.
I still need to read about those half deep hole patterns - these renders are just some rough sketches.
I will probably just use a MEMS mic with digital output fed into the AES3 encoder to gain some experience with the case shape and general handling.
For such large diaphragm capsules like the ones displayed the enclosure will probably be way too tight to let it breath and not cause lots of parasitic reflections and resonances.
The body contains the buffer, preamp, ADC (PCM42xx, e.g. PCM4201), AES3 encoder (DIT4096/DIT4192), 50V DC boost converter for capsule bias (LT8330) and some voltage regulators to convert the DPP (10V) into suitable levels.
The local clock source for the AES3 encoder and ADC (Ti PCM4201) will be a 24.576 Xtal. Can I hook the xtal up to the clock inputs directly or is their impedance too low? I couldn't find any specific information about the load in the datasheets, but I know that the evaluation boards for the Ti ADCs always use a buffer (I think it was a hex inverter) in between, but those boards have multiple clock sources and switchable clock inputs where they need to decouple the xtals. If possible I would like to leave out a buffer.
Cheers
Shu
Old 19th February 2016, 06:37 PM   #2
Here's the repo with the drafts, 3d models and EDA schematics: https://github.com/FreeAudioTechnology/violet
Bruel Kjaer Microphone Carrier System 2631 Theron Analogue Source 1 28th February 2013 05:06 PM
AES3 and SPDIF jasonkee111 Digital Line Level 0 26th August 2009 02:27 PM
added the deq2496 to my system..now there's feedback from microphone!! sqlkev Instruments and Amps 2 3rd March 2006 04:24 AM
Copyright 1999-2017 diyAudio
