Old 18th August 2004, 06:04 PM   #21
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
The only reason for having an aerial amplifier is to overcome the losses down the cable to the receiver - and that means it should be a mast-head amplifier, probably with quite low gain (6dB). Anything else is likely to amplify muck and expose the receiver's front-end to overload and intermodulation. Nothing beats a better aerial.
Actually, one thing does. A better feeder. Most aerial cable is so leaky that it picks up as much signal as the aerial. Trouble is, unlike the aerial, it's not tuned and it's not pointed in the right direction. Use a proper low loss professional cable with a foil Rheunissen screen.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th August 2004, 09:57 PM   #22
ALW is offline ALW  United Kingdom
This is exactly the reason I recommend excessive antenna gain.
Feeder pickup is always a fixed, constant value (for a given installation) and always non-zero. By having excessive gain and therefore signal strength, you can attenuate at the receiver input. This brings the input signal to the correct level, whilst attenuating the fixed, unwanted, cable pickup.
Andy.
Old 18th August 2004, 11:08 PM   #23
EC8010's Avatar
Good thought.
Old 19th August 2004, 12:18 AM   #24
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
I dug out my old Heathkit switched attenuator (up to 70 db)
and plugged it into my mediocre Fisher tuner. No amount of
attenuation will drive most of the local stations into the
noise. Cheap plastic case and open wiring still leaks in
a useable amount of signal. I'll have to try to rewire the
input with proper coax; originally it was 300 ohm balanced, to
which I'd added a balun and a F connector on the back panel.
I was hoping to make a guess as to how much signal that jpole
is pulling in; wonder if my ham neighbor has a RF microvoltmeter?
My presently defunct Heathkit AJ-29 was modified for coax and
that effectively eliminated leakage.
At one time I had a FM band JFET preselector, designed by Bob Cooper, I think; it actually worked fairly well in combination
with the attenuator (which originally came with the IM-57 TV
sweep generator). There are other ham tricks I haven't tried,
such as tuned cavity traps and bandpass filters, but I haven't
been in a position to need such, yet.
I found some general comments on RF amplifiers and preselectors
with a working example of a low-noise MOSFET preamp on this page:
http://www.geocities.com/toddemslie/bf981_preamp.html
Alpine FM reception sigfrid Car Audio 26 18th April 2011 03:07 PM
Reception On Tuning Scale Not Functioning Right. Need Help 65blkbkgt Car Audio 2 15th July 2007 12:58 PM
tripath amp interfering with radio reception ractis Class D 3 9th May 2007 09:27 PM
Mp3 player FM reception. v-bro Parts 0 4th December 2006 01:06 AM
how to get better radio reception ? My96p71 Car Audio 2 15th August 2004 08:55 PM
Page generated in 0.09028 seconds (77.35% PHP - 22.65% MySQL) with 10 queries
