Technics ST-S707 tuner signal cutting out - diyAudio
Old 27th January 2016, 06:08 PM   #1
Default Technics ST-S707 tuner signal cutting out
I'm having some issues with a Technics ST-S707 tuner that I recently picked up.
I'm hoping someone with more expertise than myself (nil) with tuners can help me out with this. The tuner pulls in a signal pretty well but as the audio level goes up, the signal seems to cut out.
It is NOT my receiver/amplifier because it is happening at the tuner. In fact I don't even have to have the tuner hooked up to anything to observe it.
I can observe it on the tuner display with the Quartz lock, FM IF and signal center display actually pulsing off and on in concert with the audio level being received.
What I mean is, if, say the DJ shouts suddenly, it cuts out momentarily with the associated pulsing off/on of the previously mentioned display parameters. It's like the signal level is overloading something causing it to cut out - but the signal strength, while strong, is certainly not THAT strong.
Any ideas where to start looking. I checked all the electrolytic capacitors (changed a few suspect ones), but that had no effect on the issue.
Does it just need a tuner alignment or are there some sick parts to go after?
TIA
Old 27th January 2016, 07:39 PM   #2
gpapag is offline gpapag  Greece
gpapag's Avatar
Does it happen with the AM too?
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 27th January 2016, 08:03 PM   #3
Didn't try it but I'll check tonight
Old 28th January 2016, 01:17 AM   #4
Well, it doesn't happen on AM although the signal was so bad it took a while to determine it is an FM only issue. I did take another look at the signal strength and the signal strength seems to be dropping enough that it comes out of "lock" but it definitely happens in conjunction with the "level" as I mentioned previously.
Old 28th January 2016, 06:43 AM   #5
gpapag's Avatar
This is encouraging.
Now as this tuner is well equipped with capabilities, use the reduction method to do the initial FM troubleshooting without poking inside.
Ensure the FM antenna is properly connected.
Dial on a strong signal.
25 kHz/100 kHz tuning selector to 25kHz.
Auto/ Manual selector to Manual.
Muting to OFF
Mono/ Stereo to Mono
RF narrow
IF narrow
If the problem is due to some switch settings, the above combination is the least interfering.
If with these settings you have no signal cut-out problem, change switches position –one at a time-starting with the switches at the bottom of the list.
Keep notes on a paper of the results for each switch position.
If you want to, report back.
George
Old 28th January 2016, 04:45 PM   #6
DF96 is offline DF96  England
Most FM tuners have an off-tune mute facility. This usually uses signal strength, but some also use the degree of off-tuning. Obviously they need to remove the audio before using the discriminator output to detect off-tuning, and there will be some sort of low pass filter to do this. My guess is that an electrolytic has dried up or gone open circuit, so the muting circuit is now seeing the audio instead of just a DC level.
Try to identify the FM IF and discriminator chip. Find a datasheet for it. You will probably find that one of the pins has a cap attached to ground to do the low pass. Look for a similar cap in your tuner circuit.
Old 29th January 2016, 03:16 AM   #7
Thanks George and DF96 for some excellent advice. I'm feeling a little stupid for not reading the manual before messing around and asking questions. At any rate, the tuner has a variable muting function that can be set to 20, 30, 40 or 50db. It defaults to 30db. It can be turned off but it automatically comes back on each time a new station is tuned and must be manually turned off again, if desired.
So I can get rid of the annoying muting but it still goes in and out of stereo mode in concert with the audio level peaks. So, is it possible I still have a bad cap or does it just need an alignment?
Here is an internal photo and the subject MUTE OFF/SCAN LEVEL button
Old 29th January 2016, 11:05 AM   #8
See my post 6. If you are able to follow my advice, do so. If not, find someone else who can. Do not attempt re-alignment unless you really know what you are doing and have the necessary test equipment. As I said, the most likely cause is a cap, so you just have to find it and replace it. Do not be tempted to replace every cap, or every electrolytic; that is a good method for stopping it working altogether.
Old 30th January 2016, 07:16 PM   #9
DF96
Got it, thanks. I definitely was NOT going to try re-alignment. I do not have the expertise or the equipment.
How do I go about identifying the FM IF and discriminator chips(s)? I don't have a schematic ...
Old 31st January 2016, 12:05 AM   #10
gpapag's Avatar
Page 2, IC102
George
Sony ST-S310 tuner trouble hiwiho Analogue Source 11 24th March 2015 01:31 PM
sony st-242s tuner Carlosraj Solid State 7 10th October 2013 10:20 AM
Looking for SONY ST-80F tuner manual djoffe Solid State 0 24th July 2010 10:12 PM
Troubleshooting Tuner ST-S550ES helios999 Analogue Source 6 28th April 2010 07:20 AM
Sony ST-J55 Tuner Mods kestrel200 Solid State 9 19th March 2005 03:38 PM
Copyright ©1999-2017 diyAudio
