Thorens TD-125 LB armboard dim's
Old 26th December 2015, 05:08 PM   #1
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Default Thorens TD-125 LB armboard dim's
I am about to refurbish a TD-125, and will also be making a new plinth. I was thinking of maybe making the plinth to also fit the LB armboard, but have not been able ti find the dim's for this.Also - does anyone know if there are some additional fixings except the usual three screews?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 27th December 2015, 12:03 AM   #2
kevinkr's Avatar
Best I can remember just the screws.. Check on Vinyl Engine - The Home of the Turntable , you need to be a member to access the library but I suspect there is plenty of useful information and probably a template there for making the plinth.
I didn't understand the arm board question, perhaps I'm dense.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th December 2015, 05:55 PM   #3
rayfutrell is offline rayfutrell  United States
I have a TD125 and there are only three screws holding the arm board. I installed a Mayware Formula 4 arm and had to make a new arm board of plywood. You really need a table saw and drill press to make sure the new board is perfectly rectangular and the screw holes are perfectly vertical.
Old 27th December 2015, 06:05 PM   #4
AuroraB's Avatar
Workshop and tools are no problem
Old 28th December 2015, 12:47 AM   #5
kevinkr's Avatar
The details you need should all be available on vinyl engine..
Old 4th January 2016, 11:27 PM   #6
wanders is offline wanders  United States
Also, check theanalogdepartment.com website. Lots of detail on Thorens tables. As to the question, I believe that only one thrust plate was used for all versions of the td-125. That had three screw holes. Wider arm boards attached the same way as the standard size.
Old 6th January 2016, 08:26 PM   #7
pioux is offline pioux  France
Yes i comfirm
Thorens TD-125 LB armboard dim'sHide this!Advertise here!
TD-125 Armboard Sizing? batsong Analogue Source 5 22nd July 2013 07:43 PM
FS: SME armboard from my Thorens TD 125 mk2 johnnyk9 Swap Meet 1 8th December 2011 04:06 AM
cartridge for thorens td-125 maxpou Analogue Source 9 20th January 2010 01:06 AM
Thorens TD-125 Ken(Toronto) Analogue Source 3 31st March 2008 09:41 AM
Thorens TD 125 speed problems singinghairdo Analogue Source 22 27th February 2008 08:11 PM
