Who's measured the noise on their RIAA preamp? - Page 3 - diyAudio
Old 19th February 2004, 06:35 PM   #21
Okay, a try at posting a formula......
Working from the assumption that there are only resistors (or that the capacitors are negligable at the frequencies of interest) Otherwise, replace every R with the corresponding Z(f) and the same for en(f) and in(f).
A single opamp,
Rin+ from positive input to ground
Rf from output to negative input
Rin- from negative input to ground
en noise voltage in V/sqrt(Hz)
in noise current in A/sqrt(Hz)
k Boltzmann constant 1.38*10exp(-23) J/K
T absolute temp in K
B noise bandwidth
let Req be equal to the parallel value of Rin- and Rf
The total noise voltage:
E= sqrt{ [ sqr(en) + sqr(in*Rin+) + sqr(in*Req) + 4*k*T*(Rin+) + 4*k*T*Req ] * B}
And sqr(x)= x*x
You can use this as the noise is independent of the signal, so the result can be added by superposition. Rin+ can be the input resistance of your source in a non-inverting setup, or Rin- can be the sum of your source and one of your gain setting resistors etc...
Now, where did I put those 1500uF caps?
Whats wrong with 1500uF? I would use 4700uF
In any case, I still need to put in a regulated voltage reference as opposed to that RC network. That might make the biggest difference of all.
Good idea.
BC550 BC560 Very low noise RIAA lineup Analogue Source 131 31st August 2016 06:56 AM
Noise on the RIAA phono preAmp diarav Chip Amps 3 23rd March 2007 05:27 AM
MC Riaa preamp help/opinions please duderduderini Tubes / Valves 15 6th March 2007 02:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
Another Simple RIAA preamp ? CheffDeGaar Analogue Source 7 10th February 2004 10:34 AM
Copyright 1999-2017 diyAudio
