| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#81 |
#82 |
HI jackinnj
thanks for your fast and good work!
#83 |
well I rebuilt the phono with mad k riaa (not perfect riaa value ), in my sistem sound more balanced ,I change the r load to 47k for open up a little more .
BUT but in this jfet phono the kind of component r/c are vey important , more of little riaa deviance !!!!! I have change the good vishay mkp1847 with a mundorf s/o , with mkp the Cymbal are in the face with s/o too hidden/soft! OK little difference are normal but so big PS I will try the jackinnj riaa
#84 | |
#85 |
Hi folks.
Have some SK170GR's arriving this week, so I can get started on this project at last ![]() I have a Denon MC 103R but I don't think the gain in this circuit is enough to do it justice - anyone tried an MC with this pre? I might have to use my MM Goldring G1042 instead. Just a little confused which schematic to use: Mad Ks, the original Pacific, or the Pacific with Tschrama's fine tuned RIAA? Which design - on paper at least - offers the closest adherence to the RIAA specification? Many thanks, - John |
#87 |
#88 |
Sure !
but I can't see jfet
#89 |
Cheers for the replies
![]() Audiodesign - nice design, but a wee bit complicated (and expensive) for me at present. Will start with this Ultrasimple, then probably move to the Phonoclone next and then... well I'll take it a step at a time - lol! Nicoch46 - Sorry do you mean I need to use the BL jfets? I thought it was the GR versions required for this design? Thanks, - John |
#90 |
Johnm with 103 you must use Salsas jfet ! for correct gain
the goldring have too much output 6,5mv saturate the jfet ! aka pacific work well with 1,6-3,5 mv HIMO PS BL in pacific with 33r on surce lowered the 2HD a lot ,but I like it!
| Suggestions for RIAA preamp? | coldcathode | Tubes / Valves | 17 | 7th March 2009 07:32 PM |
| tube preamp RIAA | radiodieg | Tubes / Valves | 5 | 3rd September 2008 01:36 PM |
| Ultrasimple MM/MC RIAA Preamp mkIII | GlidingDutchman | Analogue Source | 5 | 2nd July 2008 07:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 01:52 AM |
| ultrasimple mm/mc riaa preamp | Mad_K | Analogue Source | 109 | 31st July 2004 06:34 PM |
| Page generated in 0.10087 seconds (76.86% PHP - 23.14% MySQL) with 11 queries |
