Old 27th May 2008, 12:29 PM   #51
Originally posted by GlidingDutchman
<< RANT >> HAVE ANYBODY EVEN READ MY POST???
D
My friend, what characteristics?
Noise: will go down with the square root of parrallel devices, but idle current for be proportional increased, and you need to degrease the load resistor to keep the same idle drain voltage.
Linearity: does not nessecerely improve, but you might end up with less low order, and more high order distortion.
input capacitance: will also go up, and likely bandwidth will go down.
Old 27th May 2008, 02:08 PM   #52
Thank you - that is all I wanted to know.
D
Old 25th June 2008, 03:20 PM   #53
Default Re: ultrasimple mm/mc riaa preamp 2
Originally posted by Mad_K
This crude little riaa pre is too good to be true.
Indeed it is!! Whoa - I am gobsmacked. Just now listening to Brothers in Arms using an Ortofon Salsa MC cartridge (0.3mV out)
This phonostage is a diamond in the rough!
Cheers Mad K!!
D
Old 28th June 2008, 08:15 PM   #54
johnm is offline johnm  United Kingdom
johnm's Avatar
Hi Gliding Dutchman!
Would you mind sharing your layout? I happen to have exactly the same strip board lying around and I'd love to build this to try out on my Denon 103R and Garrard 401.
Many thanks
- John
Old 28th June 2008, 08:29 PM   #55
Many thanks
- John
John
I just soldered the parts onto the tag strip in a "random" fashion with no "propper" layout (ofcoarse according to the design!).
A friend of mine and I am working on a higher gain stage in a similar fashion to MAD K's - I'll send you the details of that circuit as I believe it would be a better match for your Denon 103R.
The above circuit works well with low output MC cartridges but higher gain would be a benifit.
Also checking out the circuit to run from 12vdc (incl IC regulators etc).
Cheers
Dewald the GD
Old 29th June 2008, 12:31 PM   #56
johnm's Avatar
Many thanks Dewald - look forward to seeing the revised design
- John
Old 29th June 2008, 02:08 PM   #57
Zigis is offline Zigis  Latvia
Hi GlidingDutchman,
nice building, I am on half way building this too.
What kind PS you use, battery or regulated?
Thees violet el caps are on output?
Zigis.
Old 30th June 2008, 08:02 AM   #58
Originally posted by Zigis
Hi GlidingDutchman,
Zigis.
Hi Zigis - currently I am running it from a Pb Acid battery (2x 12vdc) but I am looking into doing a IC regulated PSU.
The violet caps are the outputs yes - will be replaced by some plastic film types in due course.
D
Old 2nd July 2008, 02:13 PM   #59
- John
John - I'll post the new schematic for discussion. I am having trouble getting the thing to work. Actually back to the original design as per Mads K.
In comparson with the EAR 834P it can most certainly do with a touch more bass or will that be treble attenuation?
D
Old 2nd July 2008, 08:54 PM   #60
I had the same feeling... it was a bit bass-light... I cured it by making a proper inverse-RIAA, and adjusting the filter section untill it was within 0.5dB...
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 08:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 02:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 08:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 02:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 07:34 PM
Page generated in 0.12369 seconds (77.14% PHP - 22.86% MySQL) with 11 queries
