Ultrasimple mm/mc RIAA preamp 2
Old 24th May 2008, 05:59 PM   #41
Stanco is offline Stanco  Italy
Stanco's Avatar
Not only 2Sk170GR but also LSK170 difficult to find....
Old 24th May 2008, 08:29 PM   #42
Zigis is offline Zigis  Latvia
I find 2SK170BL. I think it is close.
How can I measure Idss ? I newer work with JFETs before.
Wen I find pairs, better is larger Idss or smaller, for first stage, for second ?
Old 24th May 2008, 09:12 PM   #43
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Higher Idss for the first stage for best noise.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th May 2008, 01:43 PM   #44
GlidingDutchman is offline GlidingDutchman  South Africa
Can one stack the SK170 devices for better characteristics?
Is this circuit really worth while?
D
Old 26th May 2008, 01:51 PM   #45
lcsaszar is offline lcsaszar  Hungary
Connect gate to source. Then the FET will be a constant current source. Connect it to 9 to 15V and measure the current. Excpect around 5mA, in any case less than 20mA.
Old 26th May 2008, 06:20 PM   #46
xann is offline xann  Spain
Hello.
The 2SK170 is easy to find in ebay, very cheap, and in matched quads.
Sorry for my english. Bye.
Old 26th May 2008, 09:46 PM   #47
tschrama is offline tschrama  Netherlands
You can use 2SK170BL .. Idss iun the 8-to12mA is no problem. You can insert a 10-22 or even 47Ohm resistor betwwen the source and ground to properly bias the stages, whitout altering noise and transductance too much...
I did bought some 2Sk170GR just this week from ebay... 3$ a piece no less!!
Old 27th May 2008, 07:55 AM   #48
Good idea about Ebay!
I purchase 2SK170BL yesterday:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=010
Old 27th May 2008, 08:23 AM   #49
D
<< RANT >> HAVE ANYBODY EVEN READ MY POST???
D
Old 27th May 2008, 09:52 AM   #50
Thanks for tip, oshifis,
I tray it, wen fets arrived.
Zigis.
Ultrasimple mm/mc RIAA preamp 2Hide this!Advertise here!
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 07:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 01:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 07:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 06:34 PM
