Old 11th September 2007, 08:25 PM   #31
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
LSK170 should be equvivalent, just go ahead!
Mads K
Old 11th September 2007, 11:58 PM   #32
scott wurcer's Avatar
BTW you should be able to build a small adjustable -Vgs biaser with a single 1.5V cell and some BIG resistors. You could then adjust each FET for equal Id, obviating the selection/matching requrements. A 1Meg pot between ground and -1.5V and a 10Meg resistor to the gate on each should do. The same geometry FET has about the same gm at a given Id with very little sensitivity to Idss.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 12th September 2007, 06:20 AM   #33
wrenchone's Avatar
I was amazed to get an email about this thread after all this time. If you're curious about what I finally did, check out the thread "open loop follies" (use search, it works).
Old 14th November 2007, 05:47 PM   #34
Stanco is offline Stanco  Italy
Stanco's Avatar
Nothing! The 2sk170-GR not find them .... Argh!
Maybe I am stupid ... But where you have taken them?
Old 19th May 2008, 08:19 PM   #35
HI
Did someone made a PC board lay out for these MM preamp I would be imterested .
Madd K did you com pared these RIA with the Atlantic if yes wich one sound better .
Dou you have PC board for the Atlantic ,I would be intrested on a sett if that is the better one ..
Thanks for sharing with us your designs .
Greetings
Old 20th May 2008, 05:46 AM   #36
Mad_K's Avatar
I have boards for both. Send me an email
Mads K
Old 20th May 2008, 02:12 PM   #37
Hi there
I cant find any FETs (as listed here) in South Africa. What other FET's can be used?
D
Old 23rd May 2008, 10:53 PM   #38
Zigis is offline Zigis  Latvia
Very interesting design!
I just win in ebay great LP collection with Jimi Hendrix, English 60' blues, Woodstock records , and now I need new, better phono corrector.
Problem is - I can't find 2SK170.
Is it possible to replace this JFETs with other, preferable available from elfa.se or digikey.com ?
Old 24th May 2008, 06:33 AM   #39
Zigis... that is also what I like to know! Isnt there a modern eqivalent for these transistors?
D
Old 24th May 2008, 05:33 PM   #40
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by Zigis
Is it possible to replace this JFET with another, preferably available from elfa.se or digikey.com?
No. The 2SK170 or LSK170 are quite special. They have low voltage noise and a low (for a FET) 1/f corner frequency. They are also high transconductance (which is why they are low noise). You need to get on to Linear Systems for the LSK170.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 07:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 01:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 07:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 06:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
