Ultrasimple mm/mc RIAA preamp 2 - Page 30 - diyAudio
Old 24th October 2010, 07:36 PM   #291
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The bypass capacitor will roll off for a time constant indeed. Calculated like a 1st order high pass RC filter. 1000 Ohm and 100uF do fortunately give deep infrasonic turnover still.
Old 24th October 2010, 10:39 PM   #292
andyr is offline andyr  Australia
Thank you for the info, Salas.
Old 7th February 2011, 02:45 PM   #293
what i have to modify in the schematic from post #112 if i want to use it for mm?
Old 7th February 2011, 02:50 PM   #294
Salas's Avatar
Has evolved since. Go download and follow the PDF from this link. It has 37dB MM values too.
Old 7th February 2011, 03:11 PM   #295
today i`ve ordered the parts for that schematic ...and now i`ve seen it is for mc
Old 7th February 2011, 09:28 PM   #296
Salas's Avatar
There is an almost identical 40dB gain one with different B+ in post #111 in that case back from 2008. Go test that one since you ordered the parts. It only differs on some resistor values. Choose the recommended load value for R8 given your cartridge also.
Old 7th February 2011, 10:36 PM   #297
ra7 is offline ra7  United States
This is a great circuit and most any version sounds quite good. Give it a try, you won't be disappointed. And with Salas here, help is never more than a couple of hours away
Old 9th February 2011, 10:24 AM   #298
can i replace 2n5457 with 2sk170 in the ps schematic for you pdf ? i can`t find it on the site where i buy components what other transistors can replace him? ty
Old 9th February 2011, 10:51 AM   #299
Salas's Avatar
Unfortunately no. Only LSK170 by Linear Systems is analogous to the original. Make a search in the forums here, there are guys who sell 2SK170 Toshiba also.
Old 9th February 2011, 10:56 AM   #300
i want to replace 2n5457.for him i want an equivalent.guess you understood me wrong
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 07:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 01:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 07:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 06:34 PM
Copyright 1999-2017 diyAudio
