Ultrasimple mm/mc RIAA preamp 2
Old 17th December 2009, 08:25 PM   #221
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Just follow that thread and you will find the needed answers.
I already built 7 working shunts.
Old 17th December 2009, 08:41 PM   #222
ra7 is offline ra7  United States
Default Look here lucas
Originally Posted by Salas View Post
After some time all 3 sensitivity versions adopted that feature. Go at post 2706 there. A download link has a pdf overview made by member psgr and kindly hosted by Ikoflexer.
click on that tiny down arrow near the thread numbers and go to page 271.
Old 17th December 2009, 08:49 PM   #223
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Hey ra7, did you eliminate the ''hotness'' by now?
Old 17th December 2009, 10:02 PM   #224
nhinstruments
RCruz's Avatar
It would be very usefull to have some kind of index for these threads.... everytime I have a doubt and need to consult the info (or want to help others) I feel the same pain.
I keep a log in excel but it is not very straitforward to read......
As for iko´s pdf.... It is good !!!
Ricardo
Old 22nd December 2009, 05:24 PM   #225
studeb is offline studeb  United States
studeb's Avatar
i have read this and several other threads about the Pacific and some of its derivatives. A long time ago when it first appeared i was going to build it, but that didn't happen. I was about to start again, and realised the Idss of my 2sk170s are all around 12. Is it worthwhile continuing with these, or should i acquire a lower matched quad?
The original schematics did not specify the jfet grade, and that may be why some people really disliked it when they made it with higher Idss jfets?
Old 22nd December 2009, 06:17 PM   #226
It is quite possible to make this with higher Idss JFETs. I have some at 8mA. You can play with supply voltage, load and source resistors. It will also depend on what gain you want for your cartridge and main amp.
Look back a few pages, Salas had some suggestions for higher Idss JFETs. You could also try his simplistic NJFET RIAA - Page 270, post 2706 from ikoflexer has the main pdf with the full design.
Old 22nd December 2009, 07:43 PM   #227
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Look for Vishay and Wima polypropylenes, also Koa Speer resistors in Mouser.
Koa Speer resistors in Mouser, type carbons ok?
Old 22nd December 2009, 08:05 PM   #228
Salas's Avatar
They look like Kiwame, don't they? Dale RN series they carry, very good too.
Old 23rd December 2009, 01:25 AM   #229
Never used Kiwame/Riken/Allen Bradley or other carbons, I used Dale RN series that aren't carbons in Borbelys PS & are goods. I asked the Koa Speer to Mouser for regs.
Old 23rd December 2009, 10:20 PM   #230
studeb's Avatar
i remembered that post, and tried to find it. Was that using 50R timmers on the second stage source to ground to adjust the output? Or did i miss it? I was going to go with 18V, 2k4 for R2 and R5 on your post 192, omir R3, R7 and R9, and slightly different RIAA values.
Will increasing the V (say 27V) increase the gain? my current cart has 0.5mV output, phono is stage is a Dyna Pas (40db) and it lacks gas for this cart running into a B1 buffer.
I have a feeling i will end up with something else in the end, but would like to start here.
Ultrasimple mm/mc RIAA preamp 2Hide this!Advertise here!
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 07:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 01:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 07:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 01:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 06:34 PM
