| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Well, could you correct this one
![]() Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#12 |
That looks horrible, but correct. You forgot the G-D-S on the second JFet
Maybe I'll have to make a real schematic for you
Mads K |
#13 |
Considering its made in MS-Paint....its ugly but readable. The second fet is left out intetionally, since theyre identical.
Im fine with the "back o' napkin" solution, thats how i do schematics as well. I dont even have software for making schematics or simulation for that kind of matter. Anyhow, its a great RIAA you made there....ill make a clone right away Magura
#14 |
What about substitutes for the SK170GR mosfets??
Any IR or On semi equalents (an ON semi cross ref. search didnt suggest any)??? Magura
#15 | |
![]() -Good for you. BTW, have you read this? http://www.audionote.co.uk/anp2.htm And this ? http://www.audionote.co.uk/anp1.htm (which I think is even better) edit: 2SK147 and 2SK117GR are drop-ins. Don't really know about any IR or ON parts. Many JFETs can be used, but I believe the Toshiba parts are particulary good sounding units. One other thing; you need to check the recommended load capacitance for you pickup and plan accordingly. I don't need any extra load C because my ClearAudio Virtouso Wood likes about 100pF and my cable is about 50pF and the Ciss of the 2SK170 is about 30pF pluss you can add a little to those numbers. edit2: and don't even consider not to use batteries with this circuit... SLA's are recommended I think (and do get 3 of them so you can have more fun with cascoding etc later )
Mads K |
#16 |
Thanks Mads
Ill make a PCB for this in the nearest future, then it will be a little easier to experiment with values without ending up with a bird nest ![]() Magura
#17 |
Nice! Then make room for a load C... I don't agree with you on the "easier to experiment" part, but we all do it the way we prefer.. We prototype HF circuits up to several GHz on gnd-planes and Mini MountTM at work, but it's obviously not for everyone. -A resistor change can be done in seconds
Mads K |
#18 |
I like to experiment on a PCB cause the risk that i get confused by something is smaller since the basic circuit is there. I usually CNC cut my PCB's so its no big deal to make such a proto board.
I know your way of doing prototyping is the RF way, and not bad, but it is confusing me to have such a mess of wires and components hanging on to a board in selected spots. Magura
#19 |
Just a question is this schematic for use with MM or MC cartridges?
#20 |
This setup is for MM, but you can use medium output MC provided you make the load R suitable for your pickup. If you need more gain, you could just insert one more JFet stage before the first one for about 90dB gain (it's about 54dB as drawn). Or use a stepup trafo.
edit: if you insert a third stage, the amp inverts the absolute phase.
Mads K |
| Suggestions for RIAA preamp? | coldcathode | Tubes / Valves | 17 | 7th March 2009 08:32 PM |
| tube preamp RIAA | radiodieg | Tubes / Valves | 5 | 3rd September 2008 02:36 PM |
| Ultrasimple MM/MC RIAA Preamp mkIII | GlidingDutchman | Analogue Source | 5 | 2nd July 2008 08:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 02:52 AM |
| ultrasimple mm/mc riaa preamp | Mad_K | Analogue Source | 109 | 31st July 2004 07:34 PM |
| Page generated in 0.09939 seconds (85.71% PHP - 14.29% MySQL) with 11 queries |
