| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#181 |
Hello! I did not found 2sk170 too, as well as J110. I made a simulation according to Wrenchone's advise, using BF244A with 15 ohm source resistors and 100uF bypass caps (voltage is 30V). THD is about 2.2 with huge 2nd and 8nd harmonics! I had an idea to build something simple with "pleasant distortion"..just for grins)) but i'm in doubt now.
Riaa curve is not changed, good at least.Just noticed that with inverse RIAA connected to the ground 8th harmonic disappeared and THD is ~0.6 now. How to measure it properly? I'm novice in Microcap.
#182 |
diyAudio Chief Moderator
R4 3.3k, V2 24V. No C5,C6, you need some degeneration to lower THD. Do you have 2SK170BL model? So to compare what you may check for BF244 to match THD with original.
#183 |
Thank you very much! Now THD is about 0.3 at 44 dB gain, almost entirely 2nd harmonic (I think I can deal with it
). BF244 mutual conductance is not so linear as 2sk170 at low gate-source voltage. i think I'll build it, maybe change jfets to 2sk170 when will find them.
#184 |
Up the Rs resistors to 27R, aim for 7-8V Vd, no less than 40dB gain, by adjusting the drain load resistors, if you are going to use 5mV MM. THD will go lower. For 2SK170 available look in http://www.hifituning24.de/0000009b2...a415/index.php
#185 |
Hello
I can't find 2sk170. Is it possible to replace this jfet with j310? Could you please help and suggest? Regards |
#186 |
J310 has enough more noise in comparison. Better with BF244A, adequate enough for MM cartridges.
#188 |
Thank you.
#189 |
Salas,
read all your posts for my problem in this thread. One question I left unanswered was the cartridge... ADC QLM 34 III... 7.8 mV. taught myself some spice. Simulated the circuit and am getting the same results as you. I can't get the THD numbers to make any sense. Dug up some old threads here and found that it is pretty unreliable for measuring THD and harmonics. Also, I'm not sure if I'm using the software correctly. Anyway, I'm etching PCBs right now (for the first time) for the circuit you posted. Its tough going... but hopefully I'll get there. |
#190 |
Good luck with your PCB. THD is going to be good enough, better than in the Pacific. When you got results, let us know.
| Suggestions for RIAA preamp? | coldcathode | Tubes / Valves | 17 | 7th March 2009 08:32 PM |
| tube preamp RIAA | radiodieg | Tubes / Valves | 5 | 3rd September 2008 02:36 PM |
| Ultrasimple MM/MC RIAA Preamp mkIII | GlidingDutchman | Analogue Source | 5 | 2nd July 2008 08:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 02:52 AM |
| ultrasimple mm/mc riaa preamp | Mad_K | Analogue Source | 109 | 31st July 2004 07:34 PM |
| Page generated in 0.10831 seconds (75.84% PHP - 24.16% MySQL) with 11 queries |
