| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#161 |
I have the AN 8 drivers, >95 db, 2.5 W Miniwatt tube amp.
Cartridge is an old ADC QLM III... i don't know anything about that cartridge. I got it with the turntable. Is it time to upgrade? ![]() I've heard better setups (my Dad has a nice Project turntable), and I don't think this cart sounds bad at all. |
#163 |
diyAudio Chief Moderator
You look for DCV under 2k4 to earth. Is that ADC having something like 30, or 32, before MKIII? If yes then a 3g tracking force 7.8mV MM cartridge. Tell me, can you turn all volume up without clipping or not?
#164 | |
#165 |
Salas,
I do not know much the cartridge... sorry! Also, I do not want to turn up the volume coz it will become too loud. Right now, I have it at about 12 o'clock on the miniwatt. Guess that means the pre is giving too much gain. The miniwatt will deliver full 2.5W for 500 mV input. The circuit you are showing has a lot of differences from the one I am using. I'm using the original circuit (attached). I'll try yours and report back. Btw, can you tell me how you measure Vds (simply stick the probes at the ends of the JFETS)? Also, what simulator are you using? Thanks a million for your help. Last edited by ra7; 11th November 2009 at 11:19 PM. |
#166 |
So, you don't use the Madk? You use the one in the last pic above? Wait, I think I have it too.
CM2000 is the sim. I am pretty sure about the models the betas etc I use for your circuit because I have ironed them out and comppared in practice for the many simplistics. Stay tuned.
#167 | |
#168 |
This one is based to what you got. I have used easy, standard values.
Much more compatible gain and output with 8mA Idss and MM, less thd, way to set the Vd to earth DC of your second stage between channels via R8 (also to match ACmV out), along some little Rs degeneration to bring it under control. Stage psu decoupling. Much better Riaa, better it not be doctored as in the original, use your input 100k trmmer load to find your preferable tone with MM carts. Its drastic and handy. |
#169 |
Salas,
thanks for all your time!!!!! Really appreciate it. For some reason, the 9V battery stack had dropped a lot of voltage over the past three four days. They total voltage was at 20 V. With that, the Vds was about 1 V. I put new batteries and now the voltage is at 23.9V. Vds for one channel reads 4.8V and for the other is 4.9V. |
#170 | |
| Suggestions for RIAA preamp? | coldcathode | Tubes / Valves | 17 | 7th March 2009 08:32 PM |
| tube preamp RIAA | radiodieg | Tubes / Valves | 5 | 3rd September 2008 02:36 PM |
| Ultrasimple MM/MC RIAA Preamp mkIII | GlidingDutchman | Analogue Source | 5 | 2nd July 2008 08:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 02:52 AM |
| ultrasimple mm/mc riaa preamp | Mad_K | Analogue Source | 109 | 31st July 2004 07:34 PM |
| Page generated in 0.22118 seconds (52.89% PHP - 47.11% MySQL) with 11 queries |
