Old 4th November 2008, 09:10 PM   #141
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
For BL, the finger touch ain't that critical, nor the warm up, because they have an almost zero tempco. The GR are very sensitive, but I don't think they are really around lately, nor preferable.
Just let your mA meter stabilize. The BLs are gonna rise the reading a little and then settle in a couple of minutes.
Old 4th November 2008, 09:11 PM   #142
RCruz is offline RCruz  Portugal
RCruz's Avatar
Thank you Salas
RC
Old 5th November 2008, 03:26 AM   #143
Thanks Nicoch46. Those PSUs look interesting (and not that expensive either). What would I use the pot for and how would I know if I needed it?
Old 5th November 2008, 10:40 AM   #144
nicoch58's Avatar
you have integrated amp or pre amp with pot?
my phono are connect to power amp and I put optivol between ...
Ps
Match: my 2sk170bl go up and down for more of 5minute....try your batch!
Sic58
Old 19th November 2008, 09:16 PM   #145
Default Q re load capacitance
Nicoch46, I have an integrated amp with pot, so I guess I won't need the pot.
I also have a question regarding load capacitance.
I note in post 15 Mad_K mentions the need to have the proper load capacitance. (I can't figure out how you guys cut and paste prior posts in the thread.) Unfortunately, the information on my pickup is unavailable. But how do you change the load capacitance on the preamp? I would like to try a few configurations and see what sounds better.
Old 19th November 2008, 09:26 PM   #146
nicoch58's Avatar
You do not know if are MM or MC ?
MC 100r to 47k no caps
MM 47k try at last add 50-100pf polystyrene or silverMica
what input amp use ?
http://www.cartridgedb.com/
Sic58
Old 19th November 2008, 11:03 PM   #147
Thanks, mine is MM and according to your database it looks like it takes a 47k load. Exactly where do I put the additional capacitor, is it on the plus side of the input?
Old 20th November 2008, 12:04 AM   #148
nicoch58's Avatar
same as 47k , plus to ground .
madk have higth input caps for MM try without
but grab a MC denon dl160 or dl110.....
Sic58
Old 10th March 2009, 10:09 PM   #149
Default power supply
I am in the process of compiling the pieces to try this project and I am not sure about the power supply.
Can I use three 9volt batteries with a 24 volt regulator?
Would I put the 2200 cap between the batteries and regulator?
Also would I need a local bypass?
If so would I put one on the drain of each jfet?
What would be a good value for the bypass cap?
Old 4th November 2009, 06:41 PM   #150
LucasAdamson's Avatar
Is there a kind electronics engineer out there that could me. I need to buy two matched pairs of 2SK170 GR (5mA) jfets, for use on an RIAA phono stage.
I can't seem to find them online, and would have a job matching them myself, so I thought I'd ask...
Many thanks
Lucas
Lucas
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 08:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 02:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 08:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 02:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 07:34 PM
Page generated in 0.11540 seconds (75.86% PHP - 24.14% MySQL) with 11 queries
