Old 29th October 2008, 11:18 PM   #131
RCruz is offline RCruz  Portugal
RCruz's Avatar
Originally posted by jazzzman
I see that amplabs.com has 2sk170bl at 20 pieces for $20. Are 20 pieces enough to ensure that I can get 4 pieces that match? I have no idea how variable the Idss is on these things.
Hi jazzman
Could you please point me a simple way to match fets.... maybe measuring Idss ?
I am building one phono stage with the help from Salas but I am quite new to these matters.
Hope I do not bore anyone with my question
Ricardo
RC
Old 30th October 2008, 12:02 AM   #132
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
ricardo:
try the site's search function.
doing so yields this link as one example:
http://www.diyaudio.com/forums/showt...63#post1626063
good luck!
mlloyd1
Originally posted by RCruz
Hi jazzman
Ricardo
Old 30th October 2008, 05:03 AM   #133
Ricardo: Here is a link to an article that explains in pretty basic language how the JFET works and how to measure Idss.
http://w7zoi.net/jfet101.pdf
Old 30th October 2008, 09:32 AM   #134
nicoch58's Avatar
+9v on drain ,tester on mA beetwen
gate and source on gnd
for good match what is important is the time, more are better, 15-30minute
becouse the idss after five start to go up and down .........
Sic58
Old 30th October 2008, 02:58 PM   #135
RCruz's Avatar
Originally posted by mlloyd1
ricardo:
Thank you very much...... As I am quite new to these subjects and considering the high tech conversations I read in this thread, I really was afraid to ask...
Now I will study the matter and report to you latter.
Ricardo
RC
Old 31st October 2008, 04:44 AM   #136
I have a couple of pretty dumb questions. Please don't kick me off the forum but:
(1) What kind of capacitors are best to use (it looks like something pretty exotic is used in Mad-K's picture (see post #2 above)); and
(2) Is there a common ground between the left and right channels?
Thanks,
Jazzzman
Old 31st October 2008, 01:09 PM   #137
nicoch58's Avatar
for resitor use Dale ,Prp are good too than if you want play with more exotic
caps I use vishay mkp 1837 on riaa but you can try polystyrene -mica
for serial caps 100nf and out clarity caps SA but the same you can play whit more exotic.....
Sic58
Old 4th November 2008, 06:45 PM   #138
Thanks, Nicoch46. How about the ground? Do you have to keep left and right channels separate, or can they share a common ground?
Jazzzman
Old 4th November 2008, 08:16 PM   #139
nicoch58's Avatar
same gnd as madk share ,but separate are better
gnd in-out rca/ in-pcb , connect out-pcb gnd only on pcb to avoid loop
psu are important too , good reg ,tray two minireg from ska-audio ....and optivol if you need a pot ...with this one you can remure the last 100k and caps are only 1uf ......
Sic58
Old 4th November 2008, 08:49 PM   #140
RCruz's Avatar
Hi
Why wait for 30 minutes... do we need the fet to heat up ?
Do fet´s become stable with temperature ?
Hegards
Ricardo
RC
Suggestions for RIAA preamp? coldcathode Tubes / Valves 17 7th March 2009 08:32 PM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 02:36 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 08:42 PM
RIAA Preamp Justcallmedad Solid State 4 2nd September 2005 02:52 AM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 07:34 PM
Page generated in 0.10967 seconds (79.98% PHP - 20.02% MySQL) with 11 queries
