Technics 1200 MkII Pitch Problem Technics 1200 MkII Pitch Problem - diyAudio
Old 12th February 2004, 05:34 AM   #1
silicuda is offline silicuda  Canada
Post Technics 1200 MkII Pitch Problem
One of my decks is giving me grief when I turn the pitch down to -8 on the slider. It makes the sound go all 'wobly' and stuff. Sort of like when you speed up and slow down, speed up and slow down the record.
The other range of the pitch slider -7 to +8 is fine.
Can someone please help troubleshoot the problem?
Thank you!
Old 12th February 2004, 06:43 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
It is very likely that the fader itself is worn out. Using contact spray is not a good idea IMO. Try find a new one.
/Hugo
Old 12th February 2004, 05:30 PM   #3
Yes it is the pitch control. If I wanted to replace this myself, how hard would it be?
..I replaced the turntable light before, and both of the clips that hold the toner arm in place.
Old 12th February 2004, 08:14 PM   #4
Netlist's Avatar
If you can handle a soldering iron there's no problem at all.
Keep in mind that there are two (actually three) type of faders.
The one for the very old 1200's, the one for the newer turntables and the variant with no center click.
If you ever replaced the light you will know if all busses felled out when you remove the rubber base. If this is not the case you have the newer model.
This is important to know because the fader for the old model is different.
So, if you have an old model you should order EVBJ05C19ABE
The new model fader part number is SFDZ122N11
/Hugo
Old 12th February 2004, 08:41 PM   #5
I have a version with no click on both MKII's of mine, I am picking up the fader replacement part from some old guy who repairs the decks here.
Old 12th February 2004, 08:49 PM   #6
JodyG is offline JodyG  United Kingdom
Hugo,
do you know if it's possible to replace the pitch control in a 1210MK2 with a pitch control from a 1210MK5?
Jody
Old 12th February 2004, 09:34 PM   #7
Netlist's Avatar
I have no idea as I never repaired the MK5.
I guess they could be interchangeable, probably the only difference will be the clickless fader in the MK5.
/Hugo
Technics 1200 MkII Pitch ProblemHide this!Advertise here!
Problem in pitch TECHNICS SL 1210 Willian Pires Analogue Source 4 7th February 2008 03:51 PM
Technics 1210MK3 Pitch Problem JenkoDJ Analogue Source 4 8th October 2007 11:08 AM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 01:29 PM
technics 1200 pitch correction megatron Analogue Source 4 23rd February 2004 07:11 AM
Technics SL-1200 Mk2 pitch control Clark2000 Analogue Source 18 13th August 2003 06:00 PM
Copyright ©1999-2017 diyAudio
