buzzy noise when connecting Oyaide cables - diyAudio
Old 21st August 2015, 08:43 AM   #1
Cool buzzy noise when connecting Oyaide cables
Hi
I get the buzzy noise when connecting Stanton T62 (new) with my DJM700 with Oyaide RCA cables (new).
The ground is OK.! Ive tested with other RCA-s, which are much more chipper then Oyaide..!
Please advice
Old 21st August 2015, 08:59 AM   #2
kaputt is offline kaputt  Germany
Hi! I would check again if grounding is really ok. Did you connect the GND terminal of the turntable to the terminal labeled "SIGNAL GND" at the back of your DJM700? Any piece of wire will do.
Old 21st August 2015, 09:33 AM   #3
DF96 is offline DF96  England
The cable appears to be flat, so unclear how it implements the coaxial form required by unbalanced connections. Astonishing as it might seem, a normal cheap RCA interconnect might be better.
Old 21st August 2015, 11:37 AM   #4
It's advertised as a line level cable. looking at the Oyaide website its not one of their cables, but possibly their connectors.
Old 23rd August 2015, 07:10 PM   #5
Try an old used pair of video interconnects. They use decent quality coax cable. Just strip off the 3rd cable and run the pair. Normally they are low capacitance, just what you need for a TT.
BillWojo
Old 24th August 2015, 06:39 AM   #6
Thanks guys for your advises.!
I took the simple RCA-s from my old VHS and it works.)) Ground is OK.!
Oyaide seems to be not enough shielded for that type of connections.!
Have nice day.!
Old 24th August 2015, 06:45 AM   #7
Yeah.! Its so strange from the most expensive and popular product ) Ill make a video and put it on the Youtube.!
Old 24th August 2015, 07:23 AM   #8
Buzzy Bees and Allergies TheGimp The Lounge 11 5th August 2015 04:15 AM
connecting headphones to speakers cables inside laptop abducted Everything Else 1 4th August 2014 06:36 PM
PSU noise - distance between blocks - cables length Frarun Power Supplies 10 20th May 2013 01:21 PM
Forte 1a - little buzzy, runnin' hot. bongo Pass Labs 2 16th October 2012 03:56 PM
tda2030 amp getting noise when connecting pocket tv ruleworld Chip Amps 1 15th August 2007 04:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
