Garrard 1025 turntable not working - diyAudio
Old 16th August 2015, 06:37 AM   #1
Default Garrard 1025 turntable not working
Hi
I have a Kriesler 11-104 stereo that I have inherited.
I am a complete beginner at this.The turntable made a few revolutions when I switched it on then it stopped. Where do I start to fix it? Any help or tips appreciated
Old 16th August 2015, 06:50 AM   #2
Mooly's Avatar
As I mentioned in the intros section, my experience of working on TT's is zero but if you have a look at site called 'Vinyl Engine' you should be able to get the service info for this (Garrard 1025).
If its not spinning at all then I would be looking at basics such as checking the supply to the motor. The manual should detail the route the supply takes via any switches and so on that could have failed. Also make sure the motor isn't seized. I see it says its an 'idler driver'. If the motor is spinning then it could be something as simple as the rubber idler not gripping the TT.
Good luck
Old 16th August 2015, 06:56 AM   #3
Thanks Mooly thats a great start
Old 16th August 2015, 06:59 AM   #4
Mooly's Avatar
You're welcome.
Old 16th August 2015, 07:29 AM   #5
Mooly's Avatar
This is a great resource for vintage gear.
UK Vintage Radio Repair and Restoration Discussion Forum
Just search the site for Garrard 1025. Loads of threads.
Old 16th August 2015, 07:57 AM   #6
Thanks Mooly
Garrard 1025 turntable Soundbeginner Introductions 6 16th August 2015 06:44 AM
Garrard 1025 help Soundbeginner Everything Else 1 15th August 2015 07:57 AM
garrard model S turntable ladders Analogue Source 3 14th September 2012 07:51 AM
Garrard Z2000B Turntable tyler477 Swap Meet 0 9th November 2008 09:31 AM
Garrard turntable model? Brit01 Analogue Source 4 22nd August 2008 10:00 PM
Copyright 1999-2017 diyAudio
