Suitable turntable for solid wood plinth? - diyAudio
Old 10th August 2015, 06:40 PM   #1
Default Suitable turntable for solid wood plinth?
I have been looking into getting a turntable again and particularly interested in a custom project.
I just got hold of large dry slab of chestnut with sone interesting patterns. I have been looking into what turntables I could use to create a solid wood plinth within a very limited budget.
The obvious choice is an old Rega Planner 2 as the design seems simple enough for a solid wood plinth. Then I have discovered a Linn Basik or Revolver may be in my price range. Would these be suitable to upgrade the plinth? Any other turntables that could be possibilities?
It would have to suit a solid wood plinth, be affordable ( ideally 100 or less), easy to still get parts for and good for future upgrades?
Old 10th August 2015, 07:45 PM   #2
Hi, How thick is the slab ? rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 10th August 2015, 09:57 PM   #3
Its around 8 inches but hope to make 2 plinths. A mate has a Thorens TD150 that is in desperate need of new plinth. He only wants wood round the edge unlike what I would like to do so we will end up 2 very different looking turntables.
Hopefully going to make a jig to split it with chain saw then mill each piece smooth. (car keys on wood as size context)
Old 10th August 2015, 10:09 PM   #4
AVWERK is offline AVWERK  United States
AVWERK's Avatar
As beautiful as wood is, it might wind up with high Q resonances that might contribute to a sound of its own in addition.
You just never know though, at least with MDF you get a consistent deadness you can count on.
With certain solid woods, knots can add stress points in the structure making for a crap shoot on whether it will ring or not.
If I was going for " the look" as a first choice, it might be beneficial to hollow out the underside and fill it with 2 part epoxy and lead shot or similar so you know it will be dead and still maintain the look of wood
David
Old 10th August 2015, 11:16 PM   #5
Lead Shot. Wow was not expecting that. Heh. Thanks for tip. I am up for experimenting in mixing materials with the wood, I have even considered styling this with a concrete band under where tonearm sits.
Old 10th August 2015, 11:57 PM   #6
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
I can't claim any real knowledge or experience here, but with that shape and obviously varying density, I wouldn't worry too much about resonance.
What is your goal? If you are trying to make a "perfect" non-resonant plinth, then you are probably starting with the wrong material. If you are wanting to build a bitchin' turntable that looks awesome and is all yours, then you are on the right track!
Alcohol, taken in sufficient quantities, may produce all the effects of drunkenness. - Oscar Wilde
Old 11th August 2015, 05:39 AM   #7
The wood will be trimmed to a practical size and shape. It would be interesting to still have the odd dip wheres theres a burr or some other natural features of the wood.
My Goal is although sound quality is high on the list, looks are probably the most important.
I was thinking something like this but with more interesting wood
https://www.pinterest.com/pin/360710251379141937/
Old 11th August 2015, 06:06 AM   #8
benb is offline benb  United States
I'm thinking the "or similar" could be sand (50 lb bag of "play" sand is under $5 or so at Home Depot), and it doesn't have the potential health hazard of lead.
Is there something about lead shot that makes it "better" than sand in such an application?
Old 12th August 2015, 08:21 PM   #9
FWIW if you can go to 4 or 5 inches thick, on a budget your best
bet is probably an old idler drive Lenco with a homemade long arm.
In my youth I had a Lenco, didn't rate it. However if you ditch the
very poor springs and intimately connect the top plate to a large
solid plinth apparently they are rather good, so say the fans.
The Rega by design has a low mass plinth, you'll make it worse.
The Basik and Revolver are split plinth designs, not suitable.
rgds, sreten.
Old 12th August 2015, 09:45 PM   #10
bulgin is offline bulgin  South Africa
Is the wood dry?
bukgin
Solid CLD or Hollow plinth for TD124 CijTele52 Analogue Source 1 30th October 2012 09:32 PM
TT Plinth Wood rufman Analogue Source 4 15th May 2010 09:01 AM
A new plinth for an old turntable... simeon_noir Analogue Source 8 6th November 2007 08:38 AM
Solid Wood Plinth jlsem Analogue Source 2 2nd August 2007 11:22 PM
Turntable Recommendation for Solid Plinth Project hifileslie Analogue Source 6 12th March 2007 02:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
