6 mono cartridges 0-0
Old 24th July 2015, 08:15 PM   #1
ro9397 is offline ro9397  United States
Default 6 mono cartridges $230-$650
Appreciate help in narrowing this list of prospective mono carts. Presume each would be well-matched to arm and step-up (only 2 need the latter). The associated system deserves the Miyajima Zero but credit card statement violently disagrees. For the record (no pun intended), Art Dudley likes spherical stylus, which I believe is the same as "conical" and "round."
1. Audio-Technica AT-33 Mono, approximately $525 msrp, MC .35mV “.65mil round stylus”, same body and PCOCC coil wire as AT33EV which has neodymium magnets (mono magnets unspecified, likely not neodymium) Audio-Technica - Products - Other - Professional Turntables - AT33MONO
2. Denon DL-102 $230 MC 3.0mV, “17 micron round stylus,” Herb Reichert recommended Denon DL-102 phono cartridge,Denon DL 102 phono cartridge,Denon DL102 phono cartridge,Denon DL-102 phonograph cartridge,Denon DL 102 phonograph cartridge,Denon DL102 phonograph cartridge,Denon DL-102 phono cartridge,Denon DL 102 phono cartridge,Denon
3. Ortofon 2M Mono $356, MM 4.0mV, nude spherical stylus radius 18 microns, Ortofon - 2M Mono, vinyl expert Richard Gray recommended, anonymous user rave: Ortofon 2M Mono Phono Cartridge
4. Ortofon 2M Mono SE $650 MM 3.5mV, Shibata tip possibly same as $755 2M Black Stereo which Fremer said was hypersensitive to VTA/tracking angle (the $755 2M Black Stereo and $1260 Miyajima Premium Mono BE/black ebony are Stereophile Class B) Ortofon - 2M Mono SE Fremer first listen: http://www.analogplanet.com/content/ortofons-2m-mono-special-edition-first-listen%E2%80%94world-exclusive#HSg1ZMifq0PVeSc7.97 Pro review 5-star value: Ortofon 2M Mono SE MM Phono Cartridge The future is mono! Review By Clive Meakins
5. Ortofon Quintet Mono $524, MC .3mV, nude elliptical Ortofon Quintet Mono Phono Cartridge
6. Soundsmith Otello Mono $480, Moving Iron, 2.12mV, elliptical titanium 6 x 17 microns, per SS “just slightly warmer than other SS designs,” movingcatalog
James
"Television is the poor man's whiskey." Russel Baker
Old 24th July 2015, 08:25 PM   #2
rayma is offline rayma  United States
Originally Posted by ro9397 View Post
Appreciate help in narrowing this list of prospective mono carts. Art Dudley likes
I'd agree that a spherical/conical stylus is good, other than a small HF rolloff, and
somewhat less good tracking. Also, avoid a cartridge needing a step-up device.
If you have a old Shure type III or V, you can get a third party spherical replacement stylus.
Old 24th July 2015, 08:34 PM   #3
Thanks. I listed only new carts, and the only new Shure mono is for 78s.
Is there old classic Shure mono LP cart? If so, I would consider such if stylus available. I'm glad you mentioned this. In fact, I'd consider any old MM mono LP cart for which new stylus is available.
James
Old 24th July 2015, 09:28 PM   #4
freebee is offline freebee  France
I own a Denon DL-102 cartridge and think it sounds great! The preamp I use is a modified Quad 33 which has real MONO mode (this is different to twice the left or right channel). I listen to old 33rpm Jazz records and wonder why we changed to STEREO
P.S. The cartridge has enough output to connect to a MM input. Somehow the Quad 33 phono cart works great with old carts like shure, Goldring, Denon.
Old 26th July 2015, 12:41 AM   #5
kevinkr's Avatar
Old GE VR type mono cartridges are worth a look as well, some investigation needed to get up to speed I'd hazard.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th July 2015, 03:39 AM   #6
Sorry for my being naive. I've seen "GE" cartridge mentioned several times lately. This can't possibly mean General Electric, can it?
James
Old 26th July 2015, 04:13 AM   #7
tomatamot is offline tomatamot  Netherlands
ro9397, I own several mono carts and prefere the MM type ( a personal taste )
IMHO, Make a choice between the Ortofon 2M`s.
Both track early as also modern mono records very well. ( my own experience )
Keep on spinning and have fun.
Old 26th July 2015, 02:05 PM   #8
Yes, it does.
http://www.vinylengine.com/library/g...ic/vr-ii.shtml
Old 26th July 2015, 10:40 PM   #9
kevinkr's Avatar
Believe it or not those old General Electric Variable Reluctance cartridges are excellent, you'd be hard pressed to do better by your vintage mono vinyl. Replacement styli are available in a variety of sizes for LP and 78s.
Old 30th July 2015, 02:08 AM   #10
Freddymac is offline Freddymac  United States
To my ear a well recorded stereo album can give me a solid individual position of performers and instruments on an almost three dimensional sound stage. It has taken me many years to approach this though, with good equipment in a 25 x 15 room.
6 mono cartridges 0-0Hide this!Advertise here!
Cartridges analogrules Analogue Source 9 24th May 2013 11:31 AM
Soundsmith cartridges.... a.wayne Analogue Source 3 3rd April 2013 09:42 PM
FS: Chip amp LM3886, dual mono, $650 obo Electro3000 Swap Meet 1 24th October 2012 08:29 PM
Nagaoka used cartridges Panicos K Analogue Source 1 15th October 2006 11:40 AM
Old cartridges Zero One Analogue Source 1 25th July 2006 11:22 AM
