Music from PC playing through Hi-Fi - diyAudio
Old 7th February 2004, 02:20 PM   #1
Default Music from PC playing through Hi-Fi
I have a PC which i would like to connect to my hi-fi so i can play music from my pc out of my hi-fi speakers. I have a built in soundcard thingy a sony dhc-md373 hi-fi and a analouge to 3.5mm cable and cant get it to work can anybody help???
Old 7th February 2004, 03:13 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
d0cketts,
Some possible cures:
Your line output volume settings on the PC are disabled or the slider in the control panel is down.
You connected to the wrong output jack of your soundcard.
Make sure you connect to the line in input of the Sony and your input selector is set to line in.
Your cable is bad.
/Hugo
Old 7th February 2004, 04:27 PM   #3
tool49 is offline tool49  Canada
tool49's Avatar
Integrated soundcard are often disabled in the BIOS of the PC. You should make sure it is enabled first.
DISCLAIMER: Don't play with values in your bios if you don't know what they do. It might cause your PC not to boot afterward, or cause instability with the computer. So I suggest to get the manual for your motherboard first.
Once it is enabled, do as Hugo suggested.
If it still does not work, plug some cheap speakers to your speaker out and make sure some sound comes out of them. If so, you just need to unmute/enable the line out mode. If not, you'll need to consult a PC repair specialist.
Hope this helps!
Sébastien
Old 8th February 2004, 09:21 AM   #4
K thanks guys
Now playing… martyh Analogue Source 2 27th June 2008 02:46 PM
bosoz keep playing music cowanrg Pass Labs 41 17th June 2005 11:21 PM
Playing music through the phone Elkaid Everything Else 15 2nd June 2005 05:05 PM
what's better, a mid playing high, or a tweet playing low??? cody6766 Multi-Way 10 20th February 2005 09:40 PM
JE Labs 300b round 5. MUSIC!! MUSIC!! TubeHound Tubes / Valves 14 11th January 2003 12:02 AM
Copyright ©1999-2017 diyAudio
