Technics SP 10 Speed Problems - Page 3 - diyAudio
Old 7th May 2004, 01:24 PM   #21
lectec is offline lectec  United States
Default technics sp 10
yes it did the same thing. only this one has lost its stop/start control and i cant seem to get this back. as a matter of fact i am totally bewildered as to how this start/stop button controls the brake on this unit. the wiring from the start/stop switch goes directly to a remote jack input. it has no connection to theinternal parts of the turntable. it appears as if it to send a signal to the tone arm at some remote location. there is no way for this signal to return to the turntable anyway. i am baffled. the customer assures me he has been turning the unit off and on using this button. any info on this would be appreciated.
as for the chips, again i am not yet at work where i will right down the chip numbers i changed, but they are located in two rows on the speed control board. the ones i changed can be described as the last four chips to the right on row 'b'.
this might not compute from me to you so tonight i will give you the numbers
Old 16th June 2004, 12:31 PM   #22
rollinr is offline rollinr  United States
Default Technics SP-10
If you have a Technics SP-10 with speed or switching problems, contact Wendell at Soundcom Electronics in San Antonio, Texas. He has patiently and with determination, wrung out the problems I mentioned in an earlier post. The platter spun very fast and the start switch had no effect. Wendell found faulty ICs, and managed to locate replacements, since Panasonic no longer stocks parts. The SP-10 is a fantastic, stable, rock-solid turntable, and kudos to Wendell for his tenacity in tracking down the problem. By the way, I think the ICs fried because the caps in the power supply went bad. I am now going to shotgun the power supply caps every 5 years whether they need it or not.
rollinr
Old 16th June 2004, 01:33 PM   #23
Default thanks
ahh golly gee shucks rollinr. yu a pretty nice person yourself.
lectec
Old 16th June 2004, 02:19 PM   #24
Banned
Default Re: Technics SP-10
rollinr
Don't worry, as long as you don't use Panasonic caps...
Old 20th June 2004, 06:56 PM   #25
Default I've had older Sony TTs with this problem....
and found 2 basic problems, some of which have been refered to in prior posts:
* Power Supply problems
At this age, many of the nicer Direct Drive TTs will have power supply caps that need to be replaced. Some of these can begin to cost a bit if you need to have a tech do the work as there are many involved and the bench time will not be short.
Other problems in the power supply that I've seen are:
- Operating voltages floating just outside of spec. That is, the 5v line was wandering just far out that the regulator would fall out of regulation, causing the related circuits to loose their lock. Definitely a digital-type of problem.
* Feedback problems
The biggest problem I've seen are in the feedback sensor itself. Most problems have been related to:
- Sensor adjustment to the platter's magnetic ring. I've seen some rings on platters that have lost sufficient magnetic potency that the feedback loop is interrupted. I suspect that, at some point, the platter was exposed to a strong-enough field of magnetism that it was essentially erased much like a tape demagnetizer works its magic on a tape. This is confirmed by adjusting the sensor as best as can be, then watching to see if the speed problem is related to platter rotation.
- Dirty sensors.
I've seen dust and grunge buildup on the sensors that needed to be cleaned out - most due to having been sitting long periods without a dust cover or in a really dirty place (think: back store rooms of old discos).
Hope that helps.
David
Old 20th June 2004, 07:15 PM   #26
Banned
Send a message via Yahoo to Elso Kwak
Default Technics SP 10 Speed Problems
Hi David,
The Technics SP10 does not have a magnetic rim, but some Sony DD's have.
Old 21st June 2004, 07:44 AM   #27
hnarula is offline hnarula  Indonesia
Default SP10 problems
I had this problem since some time now, and tried everything on the circuit boards, but nothing seemed to work. I then bought another off ebay, and when I got that, I changed boards one by one to see which was faulty, and ALL THE BOARDS WORKED FINE. That leaves the motor assembly, which also contains the feedback sensor.
For the question on the brakes, when the table is stopped 2 things happen, i.e. it applies a reverse force on the motor, AND at the same time activates a solenoid which in turn tightens the brake pad belt around the circumference of the motor. The solenoid can gum up, and a little WD40 sprayed on this can help, but be sure not to get any on the felt pads.
Hope this helps some of you out there who may be struggling with similar problems, 'cause there seem to be many. I spent a lot of wasted hours working on the circuit boards, when the problem was in the motor all this time. Would have never guessed it if I didn't have another for comparison.
H. S. Narula
Technics SL-1210MK2 - weird speed problem mnsh Analogue Source 98 2nd June 2016 12:31 AM
Technics SL1200 / 1210 Speed Fluctuation Problem rob110101010001 Analogue Source 5 1st September 2014 01:35 AM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 11:05 PM
Thorens TD 125 speed problems singinghairdo Analogue Source 22 27th February 2008 09:11 PM
33 speed problem on a Technics SL-QL1 mattjk Analogue Source 3 21st January 2005 06:48 PM
Copyright 1999-2017 diyAudio
