McIntosh MX118 Tuner Alignment
Old 11th January 2015, 09:39 AM   #1
willcycle is offline willcycle  United States
Default McIntosh MX118 Tuner Alignment
I have access to test equipment and would like to align the FM tuner section of my MX118. According to the service manual one of the steps involves tuning three coils and three capacitors at 90 MHz and 104 MHz respectively for best sensitivity but does not state how to measure it. McIntosh could not imply using the inaccurate led signal meter?
Old 11th January 2015, 04:03 PM   #2
DF96 is offline DF96  England
It is likely that there is a DC voltage somewhere which relates to signal strength - most FM chips produce this. This may feed the LED meter circuit. Monitor the DC voltage with a DMM. If possible, use an analogue meter if you have one - this makes it easier to spot small changes while trimming.
Old 12th January 2015, 10:17 AM   #3
stellavox is offline stellavox  United States
Front end tuning is usually pretty "broad". If you can tune in a station near both ends of the dial, use them and adjust the coils/caps for loudest signal.
Charles
Old 17th January 2015, 06:22 PM   #4
I found out using an RTA and tuning for lowest distortion is a good method. Works well and my tuner section is now aligned. Thanks for the responses.
McIntosh MX118 Tuner AlignmentHide this!Advertise here!
Stereo encoders for FM tuner alignment Conrad Hoffman Equipment & Tools 9 11th March 2013 01:31 PM
FM IC in Mcintosh MX113 tuner-pre ampliton Everything Else 2 12th August 2010 11:09 AM
Nad 7240 Tuner Alignment seabass23 Analogue Source 2 11th February 2010 01:51 PM
Mcintosh MR65 Tube Tuner tongkk Tubes / Valves 0 10th March 2006 02:59 PM
Knobs for McIntosh C26 preamplifier and MR74 tuner MOER Swap Meet 0 5th October 2003 03:42 PM
