Is it possible to feed the output of a discman to the tapehead inputs?
Old 23rd December 2014, 06:34 PM   #1
FBMinis is offline FBMinis  Portugal
Default Is it possible to feed the output of a discman to the tapehead inputs?
The plastic gears of the tape-player of an old stereo I have here broke, rendering the tape-player useless.
Can I connect the headphone output of a discman (player cd player) to the inputs soldered to the tapehead!? How?
I have actually done this and it worked but the headphone output of the discman is still too loud and it distorts once the signal gets to the tape amp.
Should I just attenuate the output of the discman or is there some filtering that must be involved?
Forgive the novice questions, I'd just like to give it a go..
Old 23rd December 2014, 06:39 PM   #2
Mooly's Avatar
You need to attenuate greatly, say a 1k and 22 ohm in series as a ballpark start point and take the output from across the 22 ohm.
You also need to remove any equalisation components from the cassette head amp (NAB curve?) so that the amplifier has a flat response.
Old 23rd December 2014, 06:44 PM   #3
rayma is offline rayma  United States
once the signal gets to the tape amp. Should I just attenuate the output of the discman or is there some filtering that must be involved?
A tape head needs equalization similar to a phono cartridge, so the Discman audio connected that way would be amplified a lot and equalized a lot. Is there another input? Or, maybe you can connect the Discman to a later point in the circuit that would just amplify it a little, or even not at all. It's probably large enough already.
Old 24th December 2014, 04:17 PM   #4
It's working properly after attenuating the signal with a simple voltage divider in each channel:
http://www.raltron.com/cust/tools/im...agedivider.gif
R1 = 10k ohm
R2 = 100 ohm
Discman volume is set to half oh playback and, when turning off and changing source, these are at the same level. No significant extra-noise noticed when using batteries, but connecting the discman to it's 4.5v transformer adds quite a bit.
Slight EQ was needed in the lower mid range but nothing as dramatic as RIAA EQ found in phono levels.
Thank you and merry christmas,
Francisco
Old 24th December 2014, 05:19 PM   #5
Mooly's Avatar
Good that you have it sorted
Is it possible to feed the output of a discman to the tapehead inputs?Hide this!Advertise here!
FS: 2 EXO-050 SINGLE-ENDED PARALLEL FEED (PARAFEED) OUTPUT TRANSFORMER NICKEL LAMS makingmoney Swap Meet 1 21st February 2012 02:59 PM
FS: ONE EXO-050 SINGLE-ENDED PARALLEL FEED (PARAFEED) OUTPUT TRANSFORMER makingmoney Swap Meet 0 18th February 2012 08:09 PM
Any inputs on the low output Grado's? scott wurcer Analogue Source 4 19th December 2009 04:20 AM
Parallel feed (choke load) in output stage yagoolar Tubes / Valves 27 17th March 2006 10:49 AM
Adding a Sub output... sum the two inputs? PaulHilgeman Solid State 9 25th February 2003 04:51 PM
Copyright ©1999-2017 diyAudio
