phono FVP5A - diyAudio
Old 20th December 2014, 11:12 AM   #1
Benji90 is offline Benji90  Italy
Default phono FVP5A
Hi everybody!
I would like to build the fvp5a phono stage as a stand alone phono preamp to be then coupled with a existing line preamp.
I have two questions about the schematics that I have found on vacuum state's website (Schematics).
First I don't understand what should the capacitor bypassing the resistor (6k8) on the first tube's grid be. It is signed as 25/25. What does it mean?
Second on the project it says that the gain control must have an exact and stable 50k impedance. Since I don't know which is the entry impedance on the line preamp and I would like to make it somehow "plug&play" I thought I could add a 50k resistor in parallel with the 1M resistor and then a capacitor in series with the output signal pathway (after the 50k resistor). Is it a good idea? I hope I have made myself clear.
Old 20th December 2014, 12:07 PM   #2
scafas is offline scafas  Italy
il condensatore e' da 25uf 25volt
Old 20th December 2014, 01:15 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
if the design needs to see a constant 50k load (?) then it means not just DC but also across the audio range. if you choose the circuit with a cathode follower at the output it will not be so sensitive to the load. The link you provided shows some schematics with cathode follower output.
This may also be of interest to you: https://darklanternforowen.wordpress...ardi-φ42/
http://mmiworks.net/sprc/SP14-Nardi.pdf
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th December 2014, 04:11 PM   #4
Thank you for your help!
On the schematics there are both the phono circuit with an anode output and subsequently the line circuit with the cathode follower output. I would like to build just the first part since I already have a line preamp. The designer says that there needs to be a stable 50k load so that there are no changes in the riaa equalization. Because of this I thought that adding a 50k resistor and then a coupling cap may help. Thank you for the design you posted! It looks very nice but I would like to build a mc phono stage without the need for a step up transformer.
Old 20th December 2014, 04:28 PM   #5
rayma is offline rayma  United States
The 50k load spec (for EACH of the balanced sides) is for the total loading, and includes your line amp. This is critical for accurate RIAA.
This loading must be AFTER the two coupling capacitors however, like the volume controls in the original circuit
Old 20th December 2014, 04:43 PM   #6
Ok thank you! So how could I solve this problem? For example in my line pre I have a stepped attenuator which can change a bit the load.
Old 20th December 2014, 04:47 PM   #7
Assuming your preamp is balanced, you could use different (50k) attenuators. Or, use a buffer circuit after the dual 50k loading. What's the circuit for your line amp?
You may be able to use a pair of directly coupled cathode followers from the phono circuit (with the 100k RIAA loading between the grids), and the coupling capacitors at their outputs.
Old 20th December 2014, 04:51 PM   #8
It is a clone of a Kondo M77 (Kondo - Audio Note M7 Tube Pre-amp Clone | DMS Audio)
Old 20th December 2014, 04:55 PM   #9
Ok, that's a straightforward circuit. Is your version a balanced or single ended line amp? The phono stage is balanced.
Old 20th December 2014, 05:28 PM   #10
ashok's Avatar
I haven't read the replies carefully. The reference to the 50K being exact at any volume level is because it affects ( is part of !) the RIAA equalisation. You will notice that there is no 1meg grid to ground resistor. So a 50 K volume pot will look like 50K at any volume position. If you add the usual 1 meg at the grid, it will NOT be 50 K at all positions.
While you could use a switched 50K volume switch, the wiper must be MBB ( make before break ) type. Otherwise you will get a bang each time you switch the volume. This is IF you do not use a 1 Meg resistor at the grid. But as mentioned before you cannot use a grid to ground resistor.
Alternate method is to just use a cathode follower with a 50K input impedance and then follow up with a stage with gain. You will have a slight noise penalty here. But possibly not of much consequence.
AM
Vacuum State FVP5A voltages rhone Tubes / Valves 33 24th November 2014 11:15 PM
jfets for fvp5a oyvinsa Analogue Source 4 24th June 2013 09:12 PM
Plate resistor for FVP5a rhone Tubes / Valves 1 22nd June 2011 03:20 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
Vacuum State Electronics FVP5A runeight Tubes / Valves 28 5th December 2003 11:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
