Marantz 6025 platter fouling issue - diyAudio
Old 17th December 2014, 09:29 PM   #1
tbj is offline tbj  United Kingdom
Default Marantz 6025 platter fouling issue
Hi all
I am currently restoring a Marantz 6025 and seem to have hit a bit of a problem.
The platter, when installed over the spindle, rubs the motor shaft and speed control arm. There doesn't appear to be any adjustment in the bearing itself - there is a little circlip that slots into a groove on the spindle to hold it in but it doesn't let you adjust the height of it.
Is the bearing worn? Is there anything else I should look at?
How can I repair the bearing?
Old 17th December 2014, 09:33 PM   #2
The most obvious cause would be the ball bearing is missing.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th December 2014, 09:42 PM   #3
rgds, sreten.
Could well be the case. I can't see a ball bearing inside the spindle hole.
Can't see how it can just be missing though, unless previous owner has been fiddling?
Anyone got any idea what size ball I need?
Old 17th December 2014, 10:04 PM   #4
kevinkr's Avatar
Post some pictures..
And check out www.vinylengine.com for manuals and perhaps other information.
Not all of these tables have a ball bearing in the main bearing. First thing to suspect however.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 17th December 2014, 10:08 PM   #5
kevinkr's Avatar
Does it look like this?
Marantz 6025 Turntable Spindle
Old 17th December 2014, 10:17 PM   #6
Looks almost exactly like that except mine has some extra holes drilled in the mounting plate.
Old 17th December 2014, 10:47 PM   #7
Hmm. Having cleaned up the bearing I think there is a ball bearing in the bottom, in fact, although I can't get it out. Stand by...
Edit: Can't quite tell if I'm looking at a bearing or the pocket where one should go. Probably the latter. I think I'll call it a night and have another look tomorrow...
Issue with Marantz PM 66KI monitoraudio Solid State 7 4th December 2013 06:51 AM
Marantz 2110 Scope Issue pezza89 Solid State 6 31st May 2012 05:16 PM
marantz 1060 issue pezza89 Solid State 3 29th June 2011 02:02 AM
marantz 1060 issue pezza89 Solid State 3 1st June 2008 11:03 AM
marantz 1180dc issue pezza89 Solid State 6 4th December 2007 08:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
