1210 ground lead!
1210 ground lead!
Old 21st January 2004, 01:10 AM   #1
Arnold_the_cat is offline Arnold_the_cat  United Kingdom
Default 1210 ground lead!
Hello, Can anyone help me? I have a technics 1210 and unfortuneatly whilst it was being transported, the ground lead got pulled out of the deck. I opened up the turntable but i have no idea where abouts the lead needs to be re-attatched.
Thanks very much.
Old 25th January 2004, 01:28 PM   #2
loonatron is offline loonatron  Australia
The same thing happened to mine! I repaired it myself, I took the rubber base off, and from memory, I think there was a small metal plate underneath, held on by one or two screws, which when removed reveal the ground lead going around plastic posts, serving as a strain releif. Not wanting to do any more dissassembly, this is where I re-attached the lead (it broke just here), by soldering, and covering with heatshrink tubing. I think I held my 1210 on its side for all this, to avoid the oil running out of the bearing (i.e. not turning the turntable upside-down) It might be safest to remove the platter whilst working on it like this!
good luck.
In emergency situations, I have tied a single strand of wire to the tonearm, which enabled the unit to be used, better than nothing eh!
Old 25th January 2004, 04:31 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi Arnold
Looking at the picture, you can see the earth cable running under the PCB. Then it is soldered to the solderlip marked with the arrow.
Hope this helps.
/Hugo
Old 26th January 2004, 12:55 AM   #4
Thanks for the replies, the picture especially. Its a big help. Cheers
Old 26th January 2004, 12:22 PM   #5
Ahh!
I was wondering how accurate my memory was! was I right about the small metal plate? That pic looks like it was directly under the base of the tonearm. Well, I'm glad that nice person posted that picture!
...Steve
Old 26th January 2004, 12:29 PM   #6
also reminds me of the inside of the lucas distributor in my old mini!
1210 ground lead!Hide this!Advertise here!
my 1210 problems herman8r Analogue Source 2 28th December 2007 02:32 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
technics 1210 M5G: Has this been rebuilt? sikniks Analogue Source 3 1st August 2006 02:04 AM
What's going on when I ground the + lead to the driver chassis? Ken L Multi-Way 0 5th August 2003 12:11 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
