Simple Clean VU Meter Driver - diyAudio
Old 6th November 2014, 10:28 PM   #1
monty78pig's Avatar
Send a message via Skype™ to monty78pig
Lightbulb Simple Clean VU Meter Driver
Hi everyone.
Here's a quick circuit I drew up the other day when I failed to find any VU meter circuits could drive a meter without giving a distorted ground current of the original signal, which is bound to cause problems unless care is taken to prevent it sharing a path with the audio signal. It's also very simple, requiring only 1 op-amp, a resistor, 4 diodes and a capacitor per channel. It does not suffer from poor sensitivity at low signal levels due to diode threshold voltage either. Whats more, the ground current is an undistorted version of the original signal, reducing the chance of distortion in the main signal path. Two meters can be built with 1 TL072.
The circuit consists of a bog standard bridge rectifier driven VU meter, but the bridge is enclosed within the feedback loop of U1. U1 must drive the bridge rectifier to produce a voltage equal to the input voltage across R1 (which can be adjusted for calibration purposes), ensuring the ground current is undistorted.
All in all a simple yet very effective design.
With perfect linearity, it is impossible to go off on a tangent. Also; My Sziklai pairs are better than your MOSFETs/Darlingtons/Pentodes/Triodes
Old 9th November 2014, 05:26 AM   #2
PRR is offline PRR  United States
PRR's Avatar
Yes, effective enough for Boonton many decades ago. (They used a row of tubes.)
I might point out that a true VU meter does not have the Ohms/uA shown in your sketch; but your plan can be trimmed to cover. One gotcha is that if the trimmer is set to zero (oops!), you can have full opamp current into the movement.
You can also avoid ground current with two opamps. At today's prices that is not a big burden. You can also simply take input differentially, which can be handy in some situations.
simple solution for VU-Meter stoppage Analog Line Level 42 13th October 2014 07:10 PM
T-amp + vu meter driver dont work Robban98422 Construction Tips 9 14th July 2014 06:55 AM
Analog VU meter/ Simple Se Swampfoot1971 Tubelab 3 14th December 2013 04:04 PM
Simple analog vu-meter driver ? 00940 Analog Line Level 10 2nd July 2013 09:34 PM
Analog VU meter driver Vrystaat Solid State 4 10th January 2013 03:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
