AR legend speed controller - diyAudio
Old 15th October 2014, 12:19 PM   #1
Default AR legend speed controller
Hi I have a AR legend turntable that has manual speed control. This involves taking the platter of and manual putting the belt onto the appropriate pulley which is a pain the neck.
The motor runs on standard 240V ac mains. I have been looking for a speed controller that I can use to change the speed electronically but cant find one. Does anyone know of one, or has built one. I could change the motor to a
24V AC version.
Can Anyone help.
Old 15th October 2014, 01:48 PM   #2
Check out the attached file. It was designed for a Lenco, which has a 20W motor and a bit of overkill for the AR, but will work just fine with a little modification for 115V use. Check out the data sheet for the XR-2206. Easy to build on a perf board.
Old 15th October 2014, 01:52 PM   #3
Oops. Forgot you said 240V ac, which is what it was originally designed for, so should be easy!
Old 19th October 2014, 10:08 PM   #4
Pyramid is offline Pyramid  United States
Pyramid's Avatar
Take a look at this: Digital PSU
If you have a 240VAC motor, you can use a travel convertor to change the output from 120 to 240V. If you have a 24V motor, plug the wall adapter into the PSU output.
FS: AR motor controller cygnus x1 Swap Meet 1 30th January 2014 04:56 PM
2 Speed Fan Controller smartx21 Solid State 30 9th May 2013 02:37 AM
Maxon motor speed controller ? komigenie Parts 2 26th March 2011 11:58 AM
DC motor speed controller Matt Rowland Analogue Source 144 28th March 2006 05:39 AM
200 amp speed controller Hayden Analogue Source 6 27th January 2006 10:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
