an observation about RIAA preamps - diyAudio
Old 11th September 2014, 09:54 AM   #1
bullpeters's Avatar
Location: Right next to beach, a potatoe toss to the whitewater
Default an observation about RIAA preamps
I have built three valve phono pre amps. All from kits so I didnt design any. They have always had hum. Recently I went MC and step up transformers. The noise floor went up and the hum was to much to bear. Not loud but annoying. So I bought a 25 dollar SS preamp for comparison. My partner, she has great ears, she picked it better, blind test. Even so, a very simple battery operated solid state system, I spent a couple hours with lead dress to get ZERO noise. Battery operated!!
What chance that I could get valvels to sound so quiet?
I have a valve amplier and will never let it be pried from my hands but big gain MC phono stage?? To difficult or immpossible
Old 11th September 2014, 10:54 AM   #2
bullpeters's Avatar
My point (I am cooking as I post) is that the noise and distortion in a power amp sounds warm and lovely, but when u lift 350mv up to you. 3.5V!, then there is just to much noise. I think its more trouble then its worth and it makes no sence.
Just my thoughts
Old 11th September 2014, 11:03 AM   #3
SY's Avatar
100%. It's a matter of care in the design, proper layout, and most important, proper grounding. The tube MC stage I use is dead quiet.
You might be screaming "No, no, no" and all they hear is "Who wants cake?" Let me tell you something: They all do. They all want cake.- Wilford Brimley
Old 11th September 2014, 02:01 PM   #4
kevinkr's Avatar
I have three diy phono stages, all vacuum tube, and all extremely quiet. It does take considerable care in construction and a certain level of design competence to end up with a quiet phono stage. Most of the kits offered on eBay are neither competently designed nor laid out for good noise performance.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 11th September 2014, 03:00 PM   #5
merlin el mago's Avatar
I use Salas Valve Itch + Jensen 1:10 step up MC transformers, zero noise and zero hum Valve Itch phono
Old 12th September 2014, 01:48 AM   #6
diyAudio Senior Member
fdegrove's Avatar
SY, are you referring to your SUT + MM phono or did you build a fully fletched valve headamp?
To TS, I can only concur with the other posters, I too run a LO MC amplified by valves only, no noise (not audible anyway) and 0 hum. Just bliss.
Frank
Old 12th September 2014, 01:58 AM   #7
SY's Avatar
My MC preamp would not make a great MM preamp if the SUT were removed. I suppose my MM preamp (also dead quiet) would also work as an MC stage with the SUT.
Old 12th September 2014, 02:27 AM   #8
fdegrove's Avatar
That's actually quite a clever design decision if you opt to use a SUT.
Frank
Old 12th September 2014, 06:39 AM   #9
bullpeters's Avatar
Please believe me, I am not trying to be argumentative, and I am no electronic engineer. I guess my point is: valves are inherently unlinear and are "noisy". Maybe that makes a warm sound in your power amplifier, but if you are trying to make a tiny voltage bigger, perhaps there are better ways?
FWIW I have a john broskie tetra RIAA preamp, which was ok till I got an MC cart and SUT. Balanced inputs, all kinds of grounding schemes, when it was past 10 oclock gain, there was noise!
I am prepared to be schooled on this. I dont pretend to know much
Old 12th September 2014, 07:02 AM   #10
bullpeters's Avatar
Seriously confused. Looked at the "valve itch" schematic layout and enclosure. Why is yours quiet and mine not? I have spent months twisting tucking and earthing to no avail. Its quiet at low gain but never ever "silent".
Just an observation tvrgeek Power Supplies 0 4th February 2010 09:35 PM
Just a senseless observation... ptwining Class D 1 13th September 2006 11:11 AM
A curious observation alexmoose Tubes / Valves 1 28th April 2006 02:09 AM
Overload considerations in RIAA preamps ashok Solid State 17 11th March 2004 12:03 PM
Simple RIAA phono preamps Optical Solid State 81 26th November 2002 10:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
