What would cause this in a vinyl record? - diyAudio
Old 7th September 2014, 01:55 AM   #1
JoeDJ is offline JoeDJ  United States
JoeDJ's Avatar
Default What would cause this in a vinyl record?
I got a vintage album that sounds great over all.
However on the lead in and between every track there is quite a lot of grove noise .....pops and clicks...... much more than "normal"
What is strange is during the songs...... even during periods of dead silence, there is no groove noise at all..... except a rare faint click here and there.
Old 7th September 2014, 02:03 AM   #2
vinylkid58's Avatar
Not particularly unusual for an older record that had been handled with dirty fingers.
jeff
Old 7th September 2014, 02:18 AM   #3
That is Strange.. Have thousands of LP's, nothing like that..
What is the album?
Old 7th September 2014, 02:51 AM   #4
JoeDJ's Avatar
It's an original US pressing of "Bob Seger - Night Moves "
Yes, I have cleaned it thoroughly.
It's strange indeed.
Old 7th September 2014, 03:20 AM   #5
What a coincidence, I've been thinking about trying to find that LP Lately..Played it to death in late 70's.. Great Songs throughout.
I hope someone can give a definitive reason.. Best guess is the lead in grooves are cut a different size and have collected more dirt..
Old 7th September 2014, 03:58 AM   #6
JoeDJ's Avatar
Yeah.... I'm thinking along that same line....
Perhaps the lead in grooves are a bit shallower and a previous owners low end stylus wore them.
My stylus is now bottoming out on those shallow worn grooves?
However, if the music grooves were deeper, perhaps that stylus never wore the depth of the groove that my relatively high end end stylus now reaches......accounting for the relatively clean non distorted music?
Aren't all grooves cut at the same time for the master though?
Old 7th September 2014, 04:08 AM   #7
vinylkid58's Avatar
C'mon you guys, have you never seen a record with big dirty thumb prints that cover about half the first track?
jeff
Old 7th September 2014, 05:36 AM   #8
JoeDJ's Avatar
jeff
Yes but, this is not a thumb print / dirty record issue.
Old 7th September 2014, 11:49 AM   #9
Jeff, read the OP carefully.
JoeDJ, what your saying is possible..
Also,Since the lead in grooves are not modulated, is it possible they wear faster or dirt presses in more permanent and if record was vacuum cleaned, the lead in grooves didn't benefit from the cleaning.. Doesn't explain the silent passages in songs having a dirt free sound..
Complete master would be cut all continuous, but lead in might be different width and/or depth..
I cant find a microscopic image showing lead in vs music groove.. Could tell a story..
We care about every issue here at diyaudio.
Old 7th September 2014, 12:09 PM   #10
kevinahcc20's Avatar
I would suspect it was caused by repeated manual cueing into these sections as someone listened to individual tracks many many times. If the tonearm used was not well damped (or maybe not damped at all) what you are hearing could be the result.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Many different Vinyl Disc/LP Clamper-Vinyl Record Stabilizer/Clamper for Sound Impr. tiefbassuebertr Analogue Source 3 7th November 2013 07:18 AM
What vinyl record did you buy today? (180gm new pressings only) freax Music 7 31st December 2012 06:09 PM
Vinyl Flat Record Flattener tiefbassuebertr Analogue Source 25 17th May 2012 07:34 AM
About using a sound card to record vinyl gaetan8888 Digital Source 16 7th May 2010 06:51 PM
How to Pirate a Vinyl Record Nordic Analogue Source 4 26th May 2006 01:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
