Thoughts on this phono stage? - diyAudio
Old 4th September 2014, 10:57 AM   #1
terranigma's Avatar
Default Thoughts on this phono stage?
I often check vinyl rips on youtube. There is a guy who has the best quality rips of my favorite songs I ever heard on youtube . Ability of resolving background details and separation amazes me. He states that he doesn't use external preamp, only Technics Su-8011's phono section. He also states that using an external equalizer.
I grabbed service manual of Su-8011 and I found that a pretty simple phono stage. I wonder if the sound signature that he got is the result of phono stage or external equalizer stage. Have any opinion on this regard? I'm attaching schematic.
Here is one of his rips:
https://www.youtube.com/watch?v=e0L8_7njSoo
Thanks.
Old 4th September 2014, 11:27 AM   #2
expert in tautology
bear's Avatar
Seems unlikely that he's' using no post processing, IF he has better quality than others - he may also be aware of the max level that Youtube can take as input, and keeps his levels proper. But somewhere in there he has to go from analog to digital, and that requires software and a computer - if he is not saying what he is using there, then he's not telling the whole story.
There is nothing special about that preamp.
The cartridge would likely make more of a difference.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- [...2SJ74 Toshiba bogus asian parts - beware! ]
Old 4th September 2014, 11:29 AM   #3
Did it Himself
richie00boy's Avatar
It looks like a fairly standard sort of design. I would say that the sound is mostly due to his EQ settings.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more.
Old 4th September 2014, 01:21 PM   #4
expert in tautology
bear's Avatar
there's no surface noise evident... no needle drop... seems highly processed, or else faked and that is a CD transfer and an LP video. Anyone hear surface noise?
_-_-bear
Old 4th September 2014, 01:29 PM   #5
Irakli is offline Irakli  United States
Irakli's Avatar
I heard pops at 3:29-3:31, so it seems its vinyl all right. Can't judge sound quality because I listened on my laptop. In any case for youtube any preamp will do OK I guess.
My System
Old 5th September 2014, 07:10 PM   #6
terranigma's Avatar
Actually his rips way better than CD releases that I have. Probably due to poor and clumsy digital mastering process of CD's.
Here are two versions (CD & Vinyl) of same recording:
http://www.youtube.com/watch?v=2EtLVcStMf4
http://www.youtube.com/watch?v=VqEVeRjGVH0
Old 6th September 2014, 12:54 AM   #7
expert in tautology
bear's Avatar
My listening on youtube is meaningless...
there are inherent differences in the masters uses for LP vs. CD in the first place. There is lower S/N on LP... mono bass, etc...
_-_-bear
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 203 5th December 2013 08:10 AM
Adding a 3rd gain stage to an MM phono stage, to make it suitable for LOMC? andyr Analogue Source 10 16th August 2012 04:10 AM
lf412 for phono preamp- thoughts? rcollege Analogue Source 5 14th November 2011 07:12 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
