Simple AM/FM receiver with pot knob not buttons - diyAudio
Old 2nd September 2014, 07:59 PM   #1
Ensoniq is offline Ensoniq  United States
Default Simple AM/FM receiver with pot knob not buttons
looking to build a simple am/fm stereo receiver with a analog type (variable resistor / capacitor ) to tune to a radio station instead of push buttons / seek.
Old 2nd September 2014, 08:16 PM   #2
rayma is online now rayma  United States
You could buy a used tuner very cheaply, or use the tuner part of a receiver from the tape out jacks. A component tuner is less likely to have AM,
but this is not very good to listen to on a good system anyway.
If you only need FM, a Dyna FM-3 can be very good with some updating.
Old 2nd September 2014, 08:23 PM   #3
i want to integrate it into one pcb assembly
Old 2nd September 2014, 08:36 PM   #4
Here's one I found, mono with optional multiplex decoder.
http://www.ramseyelectronics.com/Ram...&searchSize=12
Old 3rd September 2014, 02:10 PM   #5
kevinkr's Avatar
Perhaps something like the TEA5711? It will do stereo. I was looking for varactor tuned device but with limited time this is what I found.
http://media.digikey.com/pdf/Data%20...Fs/TEA5711.pdf
I am not sure if you were looking for an IC based solution, and I am not sure what the availability of these parts is like. Digikey does not stock it.
AM/FM Radio Receiver ICs at Digikey
You might try contacting the makers of some of the above listed parts if suitable to see whether or not you could get a few samples.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 4th September 2014, 04:48 PM   #6
Isn't tea5711 discontinued ?
Car FM/AM tuner with cd player in home use, simple receiver system Mihkus Chip Amps 6 15th March 2013 03:17 PM
AV Receiver --> Functions and Buttons FreshCheese Solid State 1 18th January 2013 03:14 AM
Pot and knob compatability AmpBuilder225 Tubes / Valves 4 25th February 2009 06:45 PM
alps pot - knob fitting woodturner-fran Parts 4 21st November 2007 09:46 PM
help removing Pot knob jkeny Parts 5 6th May 2006 01:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
