Re-Plinth DP-1100 Turntable. - diyAudio
Old 28th August 2014, 07:49 PM   #1
wrenchone's Avatar
Default Re-Plinth DP-1100 Turntable.
I have a DP-1100 turntable, that is reasonably nice. The one big drawback is that the plinth is resonant - thin, cheap wood.
On a whim, I did some trolling around on Ebay and found some sources for bamboo butcher blocks. There are some large enough that they look suitable for a TT plinth. Bonded bamboo might also be reasonably non-resonant - its certainly heavy enough to do the job. The butcher block are also pretty good-looking. Has any one tried something similar? Another possibility might be cloth-laminated phenolic resin, though that stuff gets fearfully expensive in the size needed for a plinth.
Old 28th August 2014, 08:15 PM   #2
vinylkid58's Avatar
I'd give it a try. Bamboo ply certainly works well for speaker enclosures, but it's expensive. Pretty sure I've seen the Bamboo butcher block material used for plinths, just don't ask where.
jeff
Old 28th August 2014, 08:16 PM   #3
I'd suggest hi quality marine ply, say 1/2" laminated to 1.5"/2".
That means you can simplify the cutouts to simply holes in
each layer and end up with a simply built complex structure.
rgds, sreten.
Depending on the details of the DP-1100 I'd want to couple
the two together for large flat underneath areas, YMMV.
You might also think about upgrading the arm.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 28th August 2014, 10:11 PM   #4
AVWERK is offline AVWERK  United States
Don't know if your platter is like my JVC QL-10 (in storage) but you might dampen and rebalance the platter along with the new plinth.
Most of these Asian DD,s focused on the motor back then and basically forgot about dead platters
I,ll bet you hear more differences there than the plinth, but certainly both would help.
Regard
David
Old Yesterday, 01:55 AM   #5
wrenchone's Avatar
I was looking in particular at a 18" X 24" X 2.5" butcher block made of laminated bamboo listed on Ebay. It's surprisingly cheap for what it is (the shipping is almost as much as the item costs, as it weighs >20 lbs).
Old Yesterday, 02:12 AM   #6
vinylkid58's Avatar
Is that the one from Kitchen Basics?
jeff
Old Yesterday, 03:14 AM   #7
wrenchone's Avatar
Dunno if that's the case, but if you load up Google with "Kitchen Basics Bamboo Block" you get all sorts of blocks made of all sorts of woods, any one of which would probably make an awesome plinth with about 50% of the work done for you.
Kenwood DP-1100 II doesn't turn on DJEB Digital Source 0 31st December 2012 10:33 AM
Custom-make turntable plinth Musik007 Twin Audio 9 2nd May 2012 02:30 AM
A new plinth for an old turntable... simeon_noir Analogue Source 8 6th November 2007 08:38 AM
Lightweight turntable plinth. Paul Dimaline Analogue Source 29 16th January 2006 05:32 PM
DIY Turntable plinth rookster Analogue Source 15 11th August 2003 10:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
