switch expert mod help needed - diyAudio
Old 8th August 2014, 09:05 PM   #1
Default switch expert mod help needed
Hi. I have this reel-to-reel remote control. Well, remote for the 70s in that it plugs into the back with a 15 foot cable. Hah! See attached pic.
I would like to modify the buttons.
The way it currently works is this: If you hit the PLAY button it will play. If you hit the STOP button it will stop. FF and REV self explanatory also. Now to record you must hit REC and PAUSE at the same time, then they light up. When you are ready to record you then hit PLAY and it starts to record.
I would like to modify it to this : No FF. No REV functions. No buttons. Only 2 jack inputs. If I send in a control voltage into jack 1 it will play. If the voltage into jack 1 is 0 it will stop. If I send in a control voltage into jack 2 it will record. If the voltage into jack 2 is 0 it will stop the record.
Does anyone understand this schematic and how to modify it? See pic attached. I also have the rest of the reel-to-reel schematic, but I don't think we need it.
FYI: When reel-to-reels record, I believe the erase, record, and play head are activated. When it is only playing, only the play head is activated.
Expert Advice needed Tablespider PA Systems 21 6th February 2013 01:14 PM
Transformer expert needed. nairod156 Solid State 4 13th January 2009 11:35 PM
Filter expert needed... Luke123 Solid State 11 14th April 2005 03:56 PM
TL expert needed MadMax Multi-Way 1 12th June 2003 03:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
