Turntable too fast. Caps replaced. Next step? - diyAudio
Old 21st July 2014, 01:46 AM   #1
ZackR is offline ZackR  United States
Default Turntable too fast. Caps replaced. Next step?
Hello,
I have a Project/One Model DR-770 turntable that played fine one day and then a couple days later when I went to use it, it was just turning at a very fast speed. There was no change in the speed with the 33/45 switch or the pitch control.
I used Deoxit to clean the pitch control, speed selector and the variable resistors. No change.
I then changed all the electrolytic capacitors, still no change. That is where I am now.
I am just looking for advice on what my next step should be. Should I just replace all the ceramic capacitors, transistors, and resistors and hope for the best or actually get a multi meter and try to figure out what is actually wrong with it?
I have also taken apart the motor and everything looks ok, visually, did not test anything.
Any help is greatly appreciated as to where I should turn my attention to next to try to get this thing running again. I have a new record coming in a month and I would like to get it running at a normal speed by then.
Also, I am a complete beginner with electronics, so that is why I have no idea what to do next.
Zack Rielley
Old 21st July 2014, 01:56 AM   #2
kevinkr's Avatar
Obviously you should try to figure out what is wrong with it, a far better approach and more likely to result in a fix than just randomly and blindly replacing what are most likely good parts.
Have you considered the possibility that it is nothing more than a cold solder joint? Or a crack in the PCB?
Not too sure that the meter is going to tell you much.. Might want to see if you have a friend with some experience who might be able to figure things out.
Edit: It goes without saying that you made sure warranty was expired before you attempted repairs. You might still find Project a good source of information and spare parts or not, but you have to ask to make that determination.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Baffle step correction in a FAST 2way FozzZ Multi-Way 7 12th March 2013 11:50 PM
HELP! Caps replaced-fuzzy sound sondguy Solid State 1 6th March 2009 09:11 AM
Cheap, Fast, Turntable Isolation: Sorbothane and the Enco Surface Plate DaveThreshold Analogue Source 5 21st April 2007 03:07 AM
In need of Obbligato caps FAST HolyGhostFire20 Swap Meet 1 14th December 2005 08:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
