Turntable KENWOOD KD 44-R
Old 14th July 2014, 08:19 AM   #1
andreidaniel is offline andreidaniel  Romania
andreidaniel's Avatar
Default Turntable KENWOOD KD 44-R
Hello! I bought a Kenwood turntable KD 44-R (direct drive). Works very fine, no speed fluctuations etc..soft start, soft soft and autoreturn arm. It has a problem: when you want to move the arm..even you want to fine push 1mm with hand or even with something of plastic, makes a noise somehow like you scratch the chasis or ground with an iron. I cannot identify the problem.. The only iron moving parts are a lever and a ball with drives a plastic lever.. Can be solved this problem? I even tried to clean the moving ax (axis) of the arm with spray contact but no results.
Old 14th July 2014, 09:36 AM   #2
Here are some photos with the mecanics:
Old 25th August 2014, 11:14 AM   #3
Here is the phono manual http://diyaudioprojects.com/Schemati...ice-Manual.pdf
Turntable KENWOOD KD 44-RHide this!Advertise here!
Kenwood KD-5100 turntable repair notes jb9 Analogue Source 2 21st April 2016 09:23 PM
Kenwood KD-600 coolhandproductions Analogue Source 1 10th November 2012 09:05 AM
Kenwood KD-500 "The Rock" DD Turntable $150 limono Swap Meet 5 2nd November 2012 06:09 AM
Any info about the Kenwood KD-2070 direct drive turntable ? gaetan8888 Analogue Source 1 13th November 2010 10:03 AM
Kenwood KD-2055 owners manual dstratfreak Analogue Source 3 23rd August 2007 01:11 AM
