Phono GND/shield connected to amp GND? - diyAudio
Old 30th May 2014, 11:02 AM   #1
hrs is offline hrs
Default Phono GND/shield connected to amp GND?
Being a beginner I'm working my way through my first project which is a chip amp. It has a phono input, a 'normal' input and a 3.5mm stereo jack input. It also has a loop breaker[1] so the GND of the RCA input sockets need to be disconnected from the chassis. I plan to connect the shielded signal wires to the central star on the amps power board, leaving the GND of the panel mount RCA sockets unconnected and insulated.
Looking at my record player I see that the power plug doesn't have an earth pin. Must the outer ring of the male phono interconnect comming from the record player connect to the GND of my amp for the phono shielding to work? I guess the same question applies to the mini jack which is intended for mp3 players since these don't have their own ground either.
[1] Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
Amp line level outs are floating gnd. Sub ins are common. peace brainerd Solid State 3 27th February 2013 09:50 AM
SMPS Gnd, Chassis-Gnd, and Layer Stack gearheadgene Power Supplies 1 5th July 2011 12:00 PM
Question about different gnd's on a specific amp Ermac Solid State 12 14th July 2009 07:43 AM
Type of .1uF cap to bypass Vcc & GND on chip? riotubes Parts 2 20th October 2008 03:49 PM
Why is GND of scope channels connected to case? luka The Lounge 7 18th February 2007 07:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
