How "Hi-Fi" are FM transmitters ? - diyAudio
Old 27th May 2014, 10:19 PM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default How "Hi-Fi" are FM transmitters ?
Thinking about using a small FM transmitter to sync music (from computer or ipad or even an analogue source) to an FM tuner in my house - so range is small, but quality of sound is important. Any idea if the low cost modules I see around have good sound quality ?
Mono is sufficient, so long as it sounds good.
Thanks.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th May 2014, 11:09 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Blue tooth? FM transmitter and receiver? I/R?
Velleman make a number of transmitters and receivers.
Hows about using your router with WiFi and a receiver?
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 27th May 2014, 11:12 PM   #3
ag8908 is offline ag8908  United States
you mean the things that allow you to listen to the source you're broadcasting by dialing into an FM channel (usually 87 or something like that)?
They suck a**. Horrible sound quality.
Edit: I just saw that you wrote mono is sufficient. It sounds like you're just listening to audio books or something like that. It's fine for that purpose.
Old 27th May 2014, 11:19 PM   #4
FM is used by broadcasters, universally and produce accurate results. No problems with sound quality.
Old 27th May 2014, 11:22 PM   #5
Bigun's Avatar
Yes, I mean FM broadcast not bluetooth. Mono is OK because my music listening is mostly mono - but it's not audio books, it's music. I have a Dynalab FM tuner as a source and thought I could 'stream' via this tuner.
Horrible audio quality is not going to be good enough. Sounds like this is a dead-end idea ?
Old 27th May 2014, 11:26 PM   #6
Zero D is offline Zero D  United Kingdom
Not horrible at all ! You can build one for almost peanuts to try out. Here's just a few examples.
FM Transmitter circuits with schematic diagrams
Just don't overload the input
Old 27th May 2014, 11:37 PM   #7
I got one for my car once, to listen to my MP3 player on my car's FM radio. Returned it after like 20 minutes of use. It was not at all hi-fi in any way for well recorded music. Might possibly be ok for old muddy mono songs though.
Old 28th May 2014, 12:28 AM   #8
Speedskater's Avatar
Ramsey Electronics has several kits.
AM & FM : Transmitting and Receiving : Ramsey Electronics®
Kevin
Old 28th May 2014, 01:00 AM   #9
a.wayne is offline a.wayne  United States
Sin Bin
My FM tuner lacks "hi-end" sound vs my other sources, but better than MP3 digital via internet playback, It's more dynamic and where MP3 noise is hardness, FM is analog hash..
No headaches ......
Old 28th May 2014, 01:21 AM   #10
Bigun's Avatar
did you try one yourself ?
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 72 10th April 2013 08:50 PM
Hybrid FM Stereo Encoder for FM Transmitters syamkumar Everything Else 13 25th January 2013 08:09 PM
Vegakit FM Transmitters.. xitronics Everything Else 5 31st March 2011 11:33 AM
3-way + sub woofer near field "mid" to HI-FI PC speaker system firefart_1st Multi-Way 2 10th September 2008 12:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
