How do I polish out fine scratches of record deck cover? - diyAudio
Old 24th April 2014, 01:07 PM   #1
Default How do I polish out fine scratches of record deck cover?
Just wondered if there is a method of polishing out fine swirly scratches on a perspex record player cover (without creating more of a swirly mess myself)?
Old 24th April 2014, 01:10 PM   #2
Mooly's Avatar
This stuff is good,
PLASTICCLEAN - -- - PLASTIC POLISH | CPC From This Range&MER=e-bb45-00001003
Old 24th April 2014, 01:20 PM   #3
Nice one (not pledge then?). Any special cloth required to go with it?
Old 24th April 2014, 01:31 PM   #4
I wonder if toothpaste is any good?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th April 2014, 01:45 PM   #5
Mooly's Avatar
Just a very soft cotton cloth. Maybe use an old duster. Finish off with the spray polish to get a gleaming finish.
You wonder. Toothpaste works really well on plastic headlamps that have gone milky/yellowed. You would sware that the plastic had aged but its not in many cases, its a film or layer on the surface. Use toothpaste and they come up as twinkly as new one.
Old 24th April 2014, 02:31 PM   #6
This works really well:
http://www.fako.de/00000390.html
Fakopol should be available outside Europe too.
Alternatively you can try polishing paste for motorcycle helmet viziers.
Frank
Old 24th April 2014, 02:35 PM   #7
Did it Himself
richie00boy's Avatar
not pledge then?
No as that's just a (crappy silicone) wax not a polish.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 24th April 2014, 02:44 PM   #8
msb64 is offline msb64  Canada
Toothpaste does work to some extent, but it is surprisingly abrasive.
Try it on a old cd or dvd and you can see all of the fine scratches it creates.
The best polish I have tried so far is from Novus, they have 3 grades that include a heavy & fine scratch remover as well as a clean & shine plastic polish.
NOVUS Plastic Polish
It works great, I have used it on dvds, laser discs, automotive lenses, as well as arcade machine plexiglass & acrylic displays.
The gel toothpaste I have tried would be somewhere between the heavy and fine scratch remover in cutting and polishing ability.
A power buffer with give the best results, but you can get good results by hand.
Old 24th April 2014, 03:13 PM   #9
NOVUS looks perfect for the job but, it's expensive!
Will I not get the same effect with first suggestion of PLASTICCLEAN?
Old 24th April 2014, 03:22 PM   #10
Did it Himself
I agree on the fine scratches left by toothpaste. These can be reduced by Brasso on a cloth or wadding. But there are probably better products to use in the first place. That plasticlean is probably worth a try. Just bear in mind by hand it is intensive work, it's not a quick wipe over like dusting a table.
Spring loaded Dust Cover Hinges for homebrew DIY Record Players Turntables tiefbassuebertr Analogue Source 4 28th August 2013 04:36 PM
Locking Record Mechanism on Tape deck Sunaj Analogue Source 1 18th November 2011 04:02 PM
Wanted: 16-pin, Record/Pay switch # S901 out of any Tape Deck Beaver59 Parts 0 24th June 2011 02:24 PM
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 03:29 PM
Copyright 1999-2017 diyAudio
