Software W&F meter.
Hi there,
great - thanks for the information!
However, it would be nice if frequencies other than 3kHz were possible. Not too many test records offer a 3kHz steady state test tone.
3kHz and 3.15kHz frequencies are specified for W&F measurements and only test tapes recorded with these frequencies are good for accurate speed setting and direct W&F measurements (i.e. have low residual W&f and good speed accuracy).
Good news though is that you can measure W&F reasonably well by recording 3kHz or 3.15kHz signal and playing it back 5-10 times on the same deck, than taking the average of these 5-10 measurement results. For obvious reasons you can not check the speed and speed stability this way.
Cheers
Alex
Hi Alex - thanks for the info! I think that other frequencies will be useful for measurements with tachosensor or LP. At Brüel & Kjær for this used frequency multiplier of fractional coefficients multiplication.
PS there are new versions? 🙂
