6F12P-6Ф12П passive RIAA
Old 14th March 2014, 04:00 AM   #21
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
sorry, i mean the screen grid resistor....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 14th March 2014, 01:44 PM   #22
coffin is offline coffin  Taiwan
coffin's Avatar
I soldered two diodes and the arcing was gone as predict. Result!
But now the sound of this RIAA seems to lack the low frequency......I will test it next week some time.
Ignorance and self-centered are the epidemics of human.
Old 14th March 2014, 03:59 PM   #23
kevinkr's Avatar
Good start, now to figure out why the bass is not right.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd March 2014, 06:23 AM   #24
coffin's Avatar
I had simulate the circuit on TINA-TI, it seemed no major problem on bass. (well it did have some minor deviation from enhanced-RIAA curve within 0.5dB)
But when I tested on osc scope, the response rolled off at around 180Hz@-3dB / 50Hz@-6dB. On plate of the triode, there's no roll-off. On the grid of Pentode, no significant rool-off as though there's some 120Hz modulation due to the probe. And the both signals of OPT were the same - rolled off. I paralleled a 1000u/100V cap on cathode resistor of the pentode with no effect. And both channels rolled off.
So maybe I'll try to swap the pentode to first stage to see what will happen.
cheers
Coffin
Old 23rd March 2014, 05:04 PM   #25
kevinkr's Avatar
That is one possible course of action, and there are others.. First I would see what the effect of reconnecting the pentode in triode mode is, I expect the high rp of the pentode is excessive for the available primary inductance of your transformer. Another possibility would be to shunt the primary with a 5 - 10K resistance - this will reduce the available gain, but with it the source impedance as well.
Old 24th March 2014, 08:32 AM   #26
coffin's Avatar
Thanks Kevin.
I shunt a 10K resistor on primary and the -3dB drops to 40Hz, but in the same time the gain drops 9.5dB.
And then I change to triode connection, -3dB further to 13Hz and gain drops 10dB. I will listen to this later.
cheers
Coffin
6F12P-6Ф12П passive RIAAHide this!Advertise here!
Passive RIAA Equalization Calculation jbanneck Analogue Source 3 5th June 2014 02:06 PM
Passive RIAA and cap variation Klimon Tubes / Valves 7 15th January 2009 08:03 PM
LM4562 Passive RIAA jackinnj Solid State 8 28th April 2007 02:19 AM
Passive RIAA with tubes jackinnj Tubes / Valves 5 9th December 2005 09:07 PM
Passive RIAA Herrmann Everything Else 0 23rd July 2002 08:10 PM
