RIAA stage based on LT1028...
Old 25th March 2014, 02:45 PM   #21
jiiteepee is offline jiiteepee  Finland
OK, I found some site which let to calculate a LC -filter by few given paramaters. I picked a Chebyshev 8th order filter (ripple 0.01, corner 48kHz).
1. I placed the LC -filter just before final output and made some simulations, then
2. moved it to the input part just after the load components (i.e. before the input to LT1028) and made same simulations. Results attached.
Which is the right place for LC -filter, 1 or 2 or is it better to be somewhere else?
Old 26th March 2014, 09:16 AM   #22
NOTE: FFT windowing type isn't equal in above two pictures --> transient analysis result for #2 (shown in picture 2) is equal with the other one --> placing the LC-filter effects in noise only
Old 26th March 2014, 10:37 AM   #23
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The LC filter is supposed to be on the supply rails of the LT1028. Therefore there will be two, one for each polarity of supply. I'm not sure any difference will show up in simulation as few opamp macromodels handle supply rail currents correctly.
I remembered that LC filtering was used on the USB supply rail to the ODAC but when I went to link to the schematic, I got an error as if that pdf had been moved. Hence no example to show you.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 26th March 2014, 11:02 AM   #24
Thanks!
Now that I know where to implement the filter I'll keep searching if there are some examples available.
Old 26th March 2014, 11:21 AM   #25
About those noise results I got ... are those OK (different units between LTSpice and LT datasheet) ? Got ~221 nV/Hz½ for 1kHz (measured between 999.99Hz-1.01kHz).
Couple noobie questions about voltages and currents:
- should I use cartridge output voltage (2.0mv 1kHz 5cm/s (or 5.6mV 1kHz 10cm/s)) or measured turntable output voltage as a parameter in SINE() command (SINE(0 0.002, {freq})?
- which would be suitable output voltage (now it is ±200mV (LT1010 outputs the same))
- which would be suitable output resistance when my intention is to connect the pre-amp to USB audio interface which offers three different type inputs ... 1,5k mic-preamp inputs, 10k line level inputs and 1M HiZ inputs?
-- how this final output resistance can be measured in LTSpice and if needed, how it is constructed/adjusted
RIAA stage based on LT1028...Hide this!Advertise here!
A two-stage MC tube based RIAA circuit triode_al Analogue Source 16 29th May 2012 03:55 PM
Phono stage with LT1028 MC input andyjevans Tubes / Valves 10 22nd January 2010 01:09 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 02:05 PM
RIAA stage, with certain requirements.. Bas Horneman Analogue Source 19 1st April 2005 03:04 AM
Batterysupply for RIAA-stage?? plysch Analogue Source 5 19th May 2004 07:07 AM
